Vagabond Drifter Camper Buildout and Mods
Discussion in 'Bay Area Metal Fabrication' started by MTNHABITOVERLAND, Mar 27, 2018.
  1. Mar 8, 2024 at 11:33 AM
    #6621
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    All they did was cut E panels. it looked way too DIY/afterthought for my taste we wont be offering anything like that as a finished product.
    As for the awning mounts if that's the brand they used it would be best to just order from the manufacturer for those.
    rob1208 likes this.
  2. Mar 9, 2024 at 9:13 AM
    #6622
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Definitely second this note, it needs a rain gutter.
  3. Mar 9, 2024 at 8:42 PM
    #6623
    jimlangfordphotography
    jimlangfordphotography Well-Known Member
    2020 TRD OR LB
    Gutters work very well, it was a quick project. Would love to have them with welded conners, sealed and coated with the camper.
  4. Mar 10, 2024 at 6:52 AM
    #6624
    tacomarin
    tacomarin ig: @travelswithchubbs
    Bay Area
    2018 DCLB TRD OR
    Prinsu Cab and Top Rack VO Drifter LED Interior, License Plate, and Reverse Lights Huskyliner Weather Beater floor mats Salex Center Console Organizers 35% Front/15% Rear Tint Debadged and De-stickered Anytime Front and Rear Cameras Brute force front bumper BAMF HC Dual swing out 285/75r17 BFG KO2 Front: ADS 2.5, EXT, RR, Clickers Rear: OME Dakar HD, ADS 2.5, EXT, RR, Clickers Stainless steel brake lines (+4 in rear) Wheeler's Offroad Superbumps Front and Rear Wheeler's Offroad U-bolt flip ECGS CV Axle Bushing SCS Stealth 6 17x8.5 wheels, matte dark bronze
    They did use the STS ones for the smaller awnings, but for bigger 270 awnings they made their own that were much beefier and had a backing plate on the inside. I’ll see if I can find a picture.
    edit: here is a pic from this thread. I’m not sure why there are different size brackets.
    https://www.tacomaworld.com/threads...ildout-and-mods.540940/page-305#post-26843496
    rockymtnbushwacker likes this.
  5. Mar 10, 2024 at 9:15 AM
    #6625
    tacomarin
    Bay Area
    2018 DCLB TRD OR
    How did you mount them? Also did you just weld up some angle or was this a product you found?
  6. Mar 10, 2024 at 9:29 AM
    #6626
    2020 TRD OR LB
  7. Mar 10, 2024 at 9:34 AM
    #6627
    Eze1139
    Eze1139 Well-Known Member
    Eric
    Reno NV
    2020 Cement TRD OR DCLB
  8. Mar 10, 2024 at 9:43 AM
    #6628
    tacomarin
    Bay Area
    2018 DCLB TRD OR
    Brilliant. I was thinking of doing something like this but using the screws under the overhang to mount it. But if VHB works then no need to overthink it.
  9. Mar 10, 2024 at 10:17 AM
    #6629
    JLee
    Jerry
    Grass valley CA
    Yep, putting rain gutters on my list of parts to design/fabricate I like that idea for sure!
    Rames and tacomarin like this.
  10. Mar 10, 2024 at 10:28 AM
    #6630
    JLee
    Jerry
    Grass valley CA
    VB didn't make any of their own brackets they sent it to shops like Mine if they designed it.
    I don't remember ever seeing those cut files but those can be recreated no problem here.
    tacomarin[QUOTED] likes this.
  11. Mar 10, 2024 at 11:38 AM
    #6631
    tacomarin
    Bay Area
    2018 DCLB TRD OR
    Yeah I was using the term “made” very loosely :D
    If you make your own I’d like to request using the same spacing as the STS ones since I already have those holes drilled in my camper :rofl:
  12. Mar 10, 2024 at 2:39 PM
    #6632
    JLee
    Jerry
    Grass valley CA
    Do you have those dimensions? I can make them to any spec really.
  13. Mar 11, 2024 at 8:16 AM
    #6633
    SenatorBlutarsky
    SenatorBlutarsky Well-Known Member
    Utah
    2017 Ford Transit by Axis Vehicle Outfitters
    I don't have my Drifter anymore but I did have those VO 270 awning brackets on mine. They required drilling through the camper and bolting the white plate on the inside. I think these were necessary, as opposed to mounting the awning directly to the camper, because the 270 awnings are too tall to fit directly. My understanding is that the bigger bracket is for the back corner as there's a lot of leverage on that spot when a 270 awning is deployed. There may be a better solution to mount 270 awnings, but I found those brackets to be very solid for about 3 years on my Drifter.
    I have an invoice for the brackets from VO if that'd be helpful at all, but I can't find any other details in my old emails from Phil.
    Here's the best pics I have of mine...
    AP1GczPZ7R2jbg-K1FIWs7l5_m665Ljf6gFIAZP-_a516096f28e07ea87df1010380e576d3f36e4df5.jpg
    AP1GczMhvhgJMxk8ZY24FWa5ZULKLMJMz4K8cma1_ff0c4e830eed6c702559d9b69378f543e26bfb1f.jpg
    AP1GczM5CNdPKl6YHWNkWF2R-19aAxwS6K1rqEYk_c1d93c22cd2935ef0c07aaa8ab6e3977ec915666.jpg
    AP1GczOydN24eeShqUxsH21L3Eg1wvRyjZnt9y0l_a6265214cf5702f0e5ba17f207f500cd03df8797.jpg
    JasonLee likes this.
  14. Mar 11, 2024 at 9:30 AM
    #6634
    tacomarin
    Bay Area
    2018 DCLB TRD OR
    1 7/8” as best as I can measure. 8mm hardware.
  15. Mar 11, 2024 at 9:31 AM
    #6635
    JLee
    Jerry
    Grass valley CA
    Found one! No problem recreating them now.
  16. Mar 11, 2024 at 10:12 AM
    #6636
    piotr1aj
    piotr1aj Well-Known Member
    Seattle, WA
    ‘17 OR QS/DCSB/MT
    Hey @JLee - I’m sure you’re already thinking about this, but stocking replacement parts like gas struts for current owners would be a great idea. One of mine has failed on the rear window recently. I found the replacement from the manufacturer, but seeing this thread get revived makes me want to order it through you to keep new orders coming in!
    If you make a solid panel option (preferably powder coated) to replace the glass, let me know! I already black out the window for privacy, so the added security feature would nice (and if it’s insulated even better).
  17. Mar 11, 2024 at 11:25 AM
    #6637
    RCRcer
    RCRcer Well-Known Member
    2015 OR DC
    If you make a solid panel option (preferably powder coated) to replace the glass, let me know! I already black out the window for privacy, so the added security feature would nice (and if it’s insulated even better).[/QUOTE]
    I had Phil replace the glass with e-panel on my back window for privacy/security. Needless to say it’s still flimsy, the weakest part of the camper and you play in hell trying to seal it from the elements (2nd Gen issues).
    Phil built a solid rear hatch out of aluminum that replaced the rear glass hatch and it was awesome. Very solid, secure and sealed really well. It would also accommodate a small window if wanted. It’s what the camper should have come with from the start. Also, it could be retrofitted to existing campers deleting the weak glass hatch.
    I believe five or six of these new hatches were installed on some of the last campers delivered. Phil was going to retrofit one on my camper but then it all went to hell. I’m hoping that once Jerry gets rolling with production he’ll be able to offer this as an option and also retrofit for existing owners.
    Maybe someone on here has a picture of the hatch I’m talking about and can share it for the group to see.
    By the way, big shout out to Jerry for all he’s doing for the Drifter and Nomad community!
    chetterthecat and rob1208 like this.
  18. Mar 11, 2024 at 2:15 PM
    #6638
    joeydurango
    joeydurango Nightfall Overland
    SW Colorado
    Heavily modified 2015 TRD w/Drifter
    Your gutters are genius. One of my few complaints about the Drifter. I will be copycatting yours soon!
    RE: Solid rear doors - I drew up an SVG file for the rear glass shape (undersized a hair), had an 1/8" aluminum plate laser-cut to spec, and 3M VHB-taped it to the glass. Super solid and looks factory. Even has a cutout for the brake light. Don't think I have the SVG file anymore, but the idea is out there for anyone to use if they want to retrofit their own Drifter. I use OSH Cut out of SLC for laser-cutting single-piece projects like that.
    Bed: The strut-lifting option could be cool, but I almost never slide the platform forward anyway. Partially because it's a pain, but also because I like to sit up there.
    On the road for the last week through Kentucky, Tennessee, Arkansas, Texas, New Mexico, and Arizona, another month to go on this walkabout... currently in Benson, Arizona before heading to points north and west.
  19. Mar 11, 2024 at 4:34 PM
    #6639
    G_W_Chonkr
    G_W_Chonkr Well-Known Member
    Enzo
    Clackamas, OR
    2020 Tacoma TRD OR
  20. Mar 12, 2024 at 9:02 AM
    #6640
    fastgherkin
    fastgherkin Easy being green.
    Colorado Springs, CO
    2015 White OR DCSB
    @JLee were you planning on using the same Thermoplastic coating that BAMF uses on your bumpers for coating the campers?
    It's kind of a rough texture, compared to a standard powdercoat and a little heavier, but able to be touched up, correct? I've never seen it in person.
