Vagabond Drifter Camper Buildout and Mods
Discussion in 'Bay Area Metal Fabrication' started by MTNHABITOVERLAND, Mar 27, 2018.
  1. Dec 10, 2018 at 2:12 PM
    #941
    MTNHABITOVERLAND
    MTNHABITOVERLAND [OP] Well-Known Member
    2016 Tacoma Camper Build Instagram: @mountainhabit
    Vagabond Outdoors Camper
    Yeah I haven’t had this issue and absolutely thought I would.
    Whew!
    Mateo5010 likes this.
  2. Dec 10, 2018 at 3:32 PM
    #942
    MTNHABITOVERLAND
    Where are you located?
  3. Dec 10, 2018 at 5:01 PM
    #943
    huruta
    huruta Well-Known Member
    Christy
    Seattle
    2015 DCLB TRD Sport
    Drifter....ARRIVED!
    MJ, Thanks for your report. Makes us glad we taped the holes and upgraded to the KB Voodoo rail caps in preparation for ours. Seems like an essential step, along with the bed stiffeners.
    Eazy.E, Sharkfrog and MJonaGS32 like this.
  4. Dec 10, 2018 at 5:39 PM
    #944
    overcast
    overcast Well-Known Member
    CA
    2012 OR Drifter
    LA
  5. Dec 10, 2018 at 9:48 PM
    #945
    MTNHABITOVERLAND
    I know of a few places with forklifts. You’d just need to have all of your parts on hand to do the fixes in a timely manner as not to hold up their business. I’m sure we can work something out if you’re willing to travel a bit.
    Feel free to dm me and let’s see if we can get it arranged.
  6. Dec 10, 2018 at 9:59 PM
    #946
    Iggy
    Iggy Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    :cheers:
    They don’t call us the Vagabond Fam for nothing!!
  7. Dec 11, 2018 at 9:42 AM
    #947
    overcast
    CA
    2012 OR Drifter
    thanks man! I'll probably need to get new KB sides so when that happens I may take you up on that. I have a road trip deadline so I'm going to give a go at trying to seal from underneath (via the bed cubbies) with crack filler and flex seal.
    For those of you who made a bedplate, what did you use for paint? I read somewhere that bed-liner isn't very healthy for enclosed spaces, and i want to moisture proof the ply.
  8. Dec 11, 2018 at 10:07 AM
    #948
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    FTFY ;)
    Also, I used Herculiner for my platform. It works great. Just make sure you dry it for a couple of days before putting it in.
  9. Dec 11, 2018 at 11:40 AM
    #949
    overcast
    CA
    2012 OR Drifter
    Perfecto. Thank you both!
    Anderson likes this.
  10. Dec 11, 2018 at 2:26 PM
    #950
    Laro25
    Laro25 Active Member
    White 2017 Tacoma TRD Off Road 4x4 LBDC
    TRD Pro Grill, Snugtop Rebel w/ Sportsman package, Prinsu Designs Rack, Weathertech mats,
    Is that painted or vinyl wrap? thanks
  11. Dec 11, 2018 at 5:54 PM
    #951
    Iggy
    Northern CA
    Check out the build
    It looks like it says satin wrapped in the quote.
    kceastsparks likes this.
  12. Dec 11, 2018 at 7:56 PM
    #952
    cwhet10
    cwhet10 IG: badassbrunette
    Cristin
    2015 Barely Stock TRD Sport
    Speaking of sealing beds, I have quite the challenge ahead of me. One of which I have absolutely no idea how I'm going to tackle. So ideas are very welcomed.
    But hey, I think I'll be the first bed caged Drifter out there if I can pull this off.
    Eazy.E, anomalyTRD, tyfoon11 and 2 others like this.
  13. Dec 11, 2018 at 9:11 PM
    #953
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    2019 Raptard 2001 TJ
    Dirt
    Sharkfrog, MJonaGS32 and rob1208 like this.
  14. Dec 11, 2018 at 11:57 PM
    #954
    snwbrdr852
    snwbrdr852 Well-Known Member
    Utah
    '17 DCSB OR V6 AT 4WD
    Maybe like a sheet of some ~1/8" rubber material with a hole to fit really snug over the shock body, and then sandwich it (bolt it?) between the wheel well and a contoured aluminum/steel plate?
    And then from the looks of it, you could probably get away with just butyl tape or some other sealant around the tubing.
    Couple other ideas, but they would involve enclosing it from the top, which would leave each side open to the road and probably invite a lot of build-up & corrosion.
    cwhet10[QUOTED] likes this.
  15. Dec 12, 2018 at 8:45 AM
    #955
    drftsub
    drftsub Sale Forum Lurker
    Santa Cruz Mountains, CA
    '13 200 Series Land Cruiser
    I would suggest heat moldible plastic or even Kydex.
    Enclose the whole area up to the bedside over the hoop, rubber seal the cross bar to the plastic.
    If it were me I would open up the holes around the shocks so you can get wrenches up there from underneath if you are planning on building out the interior of the bed to match the Drifter. It would suck to have to pull the full interior build out to pull a shock for a rebuild/revalve.
  16. Dec 12, 2018 at 8:27 PM
    #956
    cwhet10
    Cristin
    I actually thought this exact same thought. If the bed is already cut, might as well make it large enough to access from below. I have a friend who does fiberglass work and have considered something similar to what you suggested by just enclosing the whole thing. It doesn't seem too difficult of a challenge, just need to get creative.
    I figure under the cross bar is where I'll put either a smaller shelving/storage area or build something in that sort of "dead space" to house my solar batteries. Once it's fully built out, my hope is that the bed cage will literally disappear.
  17. Dec 13, 2018 at 7:14 AM
    #957
    Sharkfrog
    Sharkfrog Well-Known Member
    Cameron
    Modesto, CA
    2013 DCLB Sport Magnetic Grey
    She ain't stock anymore.
    Hey folks, I officially put down my deposit yesterday. It's going to be a long ~6 months! I'm reading through the thread now, and seeing some seriously killer set ups. Is there any kind of prep work you all would recommend? I see lots of people mentioning the KB Voodoo side rail caps, but not really sure what benefit they offer over stock. Another thing I'm wondering about is my shark fin, is there going to be an issue with clearance?
  18. Dec 13, 2018 at 7:56 AM
    #958
    SenatorBlutarsky
    SenatorBlutarsky Well-Known Member
    Utah
    2017 Ford Transit by Axis Vehicle Outfitters
    I like that idea a lot. May as well turn that area into a little storage space. I'm sure you've thought of it, but you'll definitely wanna seal your battery from the elements if you keep it near the bed cage with openings to the road. I had an inverter on my van's house battery die because it was just sitting out in the van and I got snow on it.
  19. Dec 13, 2018 at 8:27 AM
    #959
    kceastsparks
    kceastsparks Fkn Kyle
    Kyle
    Sparks, NV
    2015 DCSB, SOLD 2010 DCLB, RIP 2017 DCSB
    I plan on replacing my shark fin with a low profile antenna, I saved the link so let me see if I can find it.
    Anyone have 3rd gen kb voodoo bed rail install instructions? I picked up a set from @Porter707 and emailed @KB Voodoo but they never got back to me.
    Anderson and Sharkfrog like this.
  20. Dec 13, 2018 at 8:36 AM
    #960
    kceastsparks
    Kyle
    Sparks, NV
