Vagabond Drifter Camper Buildout and Mods
Discussion in 'Bay Area Metal Fabrication' started by MTNHABITOVERLAND, Mar 27, 2018.
  1. Apr 13, 2019 at 4:22 PM
    #1961
    MTNHABITOVERLAND
    MTNHABITOVERLAND [OP] Well-Known Member
    2016 Tacoma Camper Build Instagram: @mountainhabit
    Vagabond Outdoors Camper
    Eh it happens in every business. At least we’ve found our contact. :thumbsup:
  2. Apr 16, 2019 at 10:30 PM
    #1962
    Happy Heathen
    Happy Heathen Well-Known Member
    Erik
    Colville Washington
    2018 TRD off-road
    Good things come to those who wait!
    To me, having read lots about all of the different styles of campers offered, this one checked the most boxes by a long shot, so getting a different one sooner would be a waste to me. Once I get closer to a delivery date I’m quitting my job and going to spend a lot more time living life. I’m totally excited.
  3. Apr 16, 2019 at 10:32 PM
    #1963
    MTNHABITOVERLAND
    :cheers:
    Happy Heathen[QUOTED] likes this.
  4. Apr 16, 2019 at 10:45 PM
    #1964
    Happy Heathen
    Erik
    Colville Washington
    2018 TRD off-road
    Guess I’ll be calling Jeff at Deaver soon. I wanna just keep stock but be able to account for the weight of the Drifter, gear, rear bumper and my motorcycle. It seems like Deaver gets the best reviews.
    Eazy.E and Anderson like this.
  5. Apr 16, 2019 at 11:51 PM
    #1965
    alexplb
    alexplb Well-Known Member
    well I just picked up a habitat and can't say that I regret it. I'm 6.3" so clam style tops feel cramp to me. I like the finish and quality of the drifter but nothing beats habitat in terms of space it offers. If you are on the go though a pop up or clamshell style definitely is a better option if space isn't an issue.
  6. Apr 17, 2019 at 6:00 AM
    #1966
    aaen
    aaen Well-Known Member
    Northern Alberta
    2016 DCLB 4x4 TRD Sport BBP
    Kings, ARB Summit Bumper, SMittybilt Winch, vagabond Drifter, Prinsu Cabrac, Crusinoffroad slidersand rear bumper
    Hands down they are the best option out there. Get your weights and talk to them to get it squared away.
    Toynado likes this.
  7. Apr 17, 2019 at 6:55 AM
    #1967
    BZ4X4
    BZ4X4 Well-Known Member
    Brian
    2018 Blue Tacoma TRD Off-Road
    Is anyone using a REDARC BCDC1225D or LiFePO4 (Lithium Iron Phosphate) for a house battery? I'm contemplating both as I look at adding a second battery.
  8. Apr 17, 2019 at 7:38 AM
    #1968
    4wdExplorer
    4wdExplorer Well-Known Member
    Orange County, CA
    The Drifter has two optional mattress extensions that is not advertised online. I am definitely getting one as I like more sleeping space being 6'1".
    xsf18cdf and avbl908 like this.
  9. Apr 17, 2019 at 9:39 AM
    #1969
    snwbrdr852
    snwbrdr852 Well-Known Member
    Utah
    '17 DCSB OR V6 AT 4WD
    I'm using a BCDC1240D and love it.
    Yes, it's pricey, but once you look at everything it replaces, I think it's well worth it. Plus, my opinion is that appropriate charging is probably the number one factor in keeping batteries healthy, and therefore, getting the most value per dollar spent on batteries.
    It's a three stage charger, and actually steps up/down voltage as necessary (even with different profiles for different battery types).
    This means it eliminates any issues caused by modern variable voltage alternators.
    It acts as an isolator, even keeping house batteries as a completely separate bank while charging from the alternator.
    It acts as an MPPT solar controller.
    It will prioritize solar energy over alternator, if available.
    And all of that in one compact package, which also minimizes the wiring required.
    avbl908 and SenatorBlutarsky like this.
  10. Apr 17, 2019 at 9:46 AM
    #1970
    BZ4X4
    Brian
    Great info, thanks. What are you using for batteries?
  11. Apr 17, 2019 at 10:06 AM
    #1971
    Eazy.E
    Eazy.E Big gulps huh?!
    Erik
    Snohomish, Wa
    06 DCLB TRD Sport Trail Whale
    I don't recall, but with when using the BCDC1240D you no longer need to run a separate smart relay/isolator like the Blue sea ACR?
  12. Apr 17, 2019 at 10:08 AM
    #1972
    snwbrdr852
    Utah
    I'm just using two cheap, no-name group 31s as house batteries for now. They were advertised as AGM, but I think they're actually just sealed lead acid.
    I'm hoping that LiFePO4 prices come down some more by the time these guys die, as that weight savings would be really nice.
    Definitely keep us posted on where your system ends up.
  13. Apr 17, 2019 at 10:14 AM
    #1973
    BZ4X4
    Brian
  14. Apr 17, 2019 at 10:15 AM
    #1974
    snwbrdr852
    Utah
    Well, I guess it would depend how you're using the BCDC. If you wired it in between the alternator and starting battery, then you would still need an isolator between starting battery and house battery.
    I have my BCDC wired between the starting battery and house batteries, as I think most people would probably do, as I wanted to leave the factory charging system in tact.
    In this config, no isolator is required, as the BCDC never actually connects the two. It takes the input current, modifies it as applicable, and outputs it separately.
  15. Apr 17, 2019 at 10:20 AM
    #1975
    BZ4X4
    Brian
    The price, but the weight savings. Two LiFePO4 are about the same weight as one lead acid. I will post something if I can ever make up my mind!
    snwbrdr852[QUOTED] likes this.
  16. Apr 17, 2019 at 10:32 AM
    #1976
    snwbrdr852
    Utah
    Not to mention the efficiency, with 80% depth of discharge.
    I was looking at them for fun again the other day, and compared to my current batteries, I could get more usable amp hours for less than half the weight ...but like 6x the price.
    brehew and BZ4X4[QUOTED] like this.
  17. Apr 17, 2019 at 10:54 AM
    #1977
    BZ4X4
    Brian
  18. Apr 17, 2019 at 11:35 AM
    #1978
    snwbrdr852
    Utah
    Right, since it never connects the two, it can't be used for backup starting power.
    I have a little lithium jump pack, but I also recently got a 200A relay that I'll wire to the input and output sides of the BCDC and run a switch into the cab so I can bridge them if it ever becomes necessary.
    The alternator state has no impact on isolation, but the BCDC just switches on/off based on input voltage.
    Eazy.E likes this.
  19. Apr 17, 2019 at 1:49 PM
    #1979
    Eazy.E
    Erik
    Snohomish, Wa
    Makes sense! I suppose if your house batter is located in the engine compartment it would be easy enough to just as well haha.
  20. Apr 17, 2019 at 2:17 PM
    #1980
    aaen
    Northern Alberta
    I’ll be shifting to a 100amp battle born battery this summer. Wiring it into two solar panels with a third that is removeabke or has the ability to moved to follow the sun.
    I want this completely separate from the electronics up front and I will remove all wiring going to the second battery in the engine compartment.
    I’ll keep the second battery up front for winching, light bar and radio/etc.But thats probably it. Everything else, fridge, second radio, 12 volt/usb pors, work light, canopy, water pump, etc will all be run off the new house battery.
    snwbrdr852, Eazy.E and rajacat9 like this.
