Valance Painting question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by stormtrooper37, Sep 26, 2011.
  1. Sep 26, 2011 at 12:00 PM
    stormtrooper37
    stormtrooper37 [OP] N
    Toytec 2.5 Bilsteins Tint Rims Tires Exhaust
    so i painted my valance the other day and the paint seemed to bubble and not stick has anyone elase had this problem and or know how to fix it?
    i know its probablly some rookie mistake but im cursed when it comes to painting.
  2. Sep 26, 2011 at 12:01 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    what kind of paint did you use? did you clean the surface before you painted it?
  3. Sep 26, 2011 at 12:01 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    thats cause you didn't prep the surface correctly... you didn't sand it right?
  4. Sep 26, 2011 at 12:02 PM
    ColtsTRD
    Scott
    AZ
    just go over it with 4 coats of Plati-dip....it won't chip and your problems solved :)
  5. Sep 26, 2011 at 12:03 PM
    stormtrooper37
    i didnt sand was i supposed to ? and whats plati dip ?
  6. Sep 26, 2011 at 12:03 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Bingo...
    FWIW, if you use bedliner, you don't have to do that much prep work, that stuff sticks to anything. You need to sand that paint off and start over. Any paint you put over the top of that will just do the same thing.
  7. Sep 26, 2011 at 12:05 PM
    stormtrooper37
    ok cool thanks, your talking about the spray on bedliner from home depot right ?
  8. Sep 26, 2011 at 12:05 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Light even coats so there's no run! I used krylon fusion over a year ago and it still looks perfect!
  9. Sep 26, 2011 at 12:06 PM
    ColtsTRD
    Scott
    AZ
    Well yea if you wanted it to adhere but thats way permanent...but i guess since you used paint there's no going back...which is fine. Just use very fine sand paper and gently go over the area and apply some plasti-dip...its a black rubberized coating that you can but at most home improvement stores
  10. Sep 26, 2011 at 12:07 PM
    stormtrooper37
    alright cool
  11. Sep 26, 2011 at 12:07 PM
    stormtrooper37
    wish my other threads got this quick of a response hahah
  12. Sep 26, 2011 at 12:10 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Lol, what else you got for us? Haha
  13. Sep 26, 2011 at 12:10 PM
    Pugga
    Massachusetts
    And another one goes to the dark side of plasti-dip...
    I used spray on bedliner from Autozone, worked pretty well but you have to do light coats otherwise it runs. If you use plastidip, take off the masking tape right after you get done spraying otherwise it sticks to the tape and you won't get a clean edge.
  14. Sep 26, 2011 at 12:12 PM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    Plasti-dip is for fools, click on my build thread in my sig and check out the truck bed liner I used, will last much longer than plasti-derp.
  15. Sep 26, 2011 at 12:13 PM
    Pugga
    Massachusetts
    Good to know I'm not the only one... :cheers:
  16. Sep 26, 2011 at 12:13 PM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    :thumbsup:
  17. Sep 26, 2011 at 12:14 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    My votes krylon fusion!
  18. Sep 26, 2011 at 12:20 PM
    ColtsTRD
    Scott
    AZ
    Fools huh? Coming from a guy thats running a spacer lift... :laugh:
    was just trying to help the guy...no need to be a prick....
  19. Sep 26, 2011 at 12:32 PM
    Pugga
    Massachusetts
  20. Sep 26, 2011 at 12:34 PM
    stormtrooper37
    ill just buy what i can find
