Valentine 1
Discussion in 'Technical Chat' started by Huy3426, Dec 20, 2007.
  1. Dec 20, 2007 at 7:33 PM
    Huy3426
    Huy3426 [OP] Member
    I got a Valentine 1 radar and wanted to plug it directly to the car instead of using the cigarette plug...i just need an easy access to a power and ground wire where i can slice into it...where is the best and shortest place i can do this? :confused:
  2. Dec 20, 2007 at 7:40 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    well...if u want the best, i'd prolly say to put a fuse inline and run it straight to the battery and run the ground to where the the fuse box grounds....that or wire it up to an empty slot in the fusebox itself...but for easiest, i have no idea
