Valve adjustment necessary?
Discussion in 'Technical Chat' started by Terminous, Oct 20, 2011.
  1. Oct 20, 2011 at 1:18 PM
    Terminous
    Terminous [OP] Member
    San Joaquin Delta, Ca
    Stock 05 Prerunner
    Hello all. I now have 128k on my '05 Tacoma Pre runner with the 1GR-FE. I spin a wrench for a living (diesel truck) and know the importance of well adjusted valves in regards to performance, fuel economy and valve train wear. I have looked all through my maintance manual and found nothing on recommend valve adjustment intervals. I do have some valve train noise (ticking) but have been told by the dealer while under warranty that it is normal noise. The performance is a little sluggish lately, and yes, I have changed the plugs recently.
    Has anyone found an adjustment to be necessary and if so does this engine use valve shims to obtain correct clearance or is it a straight adjuster and lock nut affair? Thanks in advance for your help in this!
  2. Oct 20, 2011 at 2:00 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Its a shim under bucket design, but I havent seen them out of spec after 200+ k miles..
  3. Oct 20, 2011 at 2:06 PM
    Texoma
    Texoma IG: cwehlin
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Unless someting is wrong, or it is running rough, no adjustment necessary.
  4. Oct 20, 2011 at 2:06 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    A friend of mine had 580k miles when he had his done...and they werent that far out of specs....
  5. Oct 20, 2011 at 4:19 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    Are they not "self-adjusting" ??
  6. Oct 20, 2011 at 4:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No.
  7. Oct 20, 2011 at 11:13 PM
    Terminous
    Stock 05 Prerunner
    Thanks for your input guys, sounds like i'll leave 'em alone unless they develop a firm need to be adjusted.
  8. Oct 22, 2011 at 2:16 AM
    qnyla
    qnyla Well-Known Member
    NM
    2006 & 2016 DCSB TRD Off Road 6-Speed
    My 2006 is at 256k and I have yet to see a need to adjust them.
