Valve adjustment
Discussion in '1st Gen. Tacomas (1995-2004)' started by Panda Cub, Jan 23, 2011.
  1. Jan 23, 2011 at 4:09 PM
    Panda Cub
    Panda Cub [OP] Member
    Chicago
    00 Tacoma 4x4
    Cap
    Here is the story:
    I have a 2000 taco with the 2.7l.
    My taco has 143,000 miles on it, and it is idling a little rough, so I consulted my father who is a mechanic and he told me it needed a valve adjustment. I bought the special tools to get into the engine, but I need to get shims. I know that I need to check what shim I need to get after I take the engine apart. Has anybody done this job before? How expensive are shims? Will a dealer have the shims so I can pick them up while I have the engine apart?
    Anybody have any idea what size shims they used? I know that I will have to measure before purchasing, but possibly I can buy multiple sizes of shims and return the ones I do not use.
  2. Jan 23, 2011 at 4:12 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    You should be able to get the shims anywhere, like a NAPA, or the like. However, I have never seen a set that needed to be replaced with that little milage on it. You may want to donsider other things that might be the issue.
  3. Jan 24, 2011 at 3:10 AM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    X2. I have 145k and never had a valve adjustment and it doesnt need one either. Mine ran alil rough also but cleaned the Throtthe body, IAC, MAF Sensor, Seafoamed and cleaned spark plugs and it runs SMOOOOOOOTH!!!
