When to do valve adjustment?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OCTaco, Mar 25, 2010.
  1. Apr 27, 2010 at 11:37 PM
    Peru
    Peru Well-Known Member
    Jonathan
    Redmond WA
    SR5 -- V6 -- 2005 -- 4X4
    none
    X2 what he said. If left out of spec the ensuing damage will cost a whole lot more than a couple of hrs and the price of shims.
    Don't ask me how I know.
  2. Apr 7, 2011 at 1:50 AM
    bwill808
    bwill808 Active Member
    bryan
    hawaii
    00 extra cab 5lug trd supercharged
    trd supercharger the grey version , k&n intake , trd headers , 2 1/2 inch catback
    so whats better loose .014 , or tighter , smart guy i dont know, read a forum stating .015 for v6 is ideal , but , the spec is .011 .014 i have asked wrote like 100 forums with no straight answer ffrom any one, i dont want to be the guuiny pig but i will if i have to , . the new v6 1gr tacoma etc. changed there spec to include .015 , i am debating . what do u think about burnt shims hot spots , same for my cams r they ruseable
  3. Apr 7, 2011 at 7:35 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Loose (a little) is better than too tight. Thats why the specs dont go lower than .011.
    racerX969 likes this.
  4. Jan 9, 2016 at 11:37 PM
    EJPHI
    EJPHI Well-Known Member
    N CALI
    2003 2.4l 5sp 5 lug
    pt474 cruise control Alpine head unit
    I'll echo a lot of what Davidch said 5 years ago.
    I just did this on my new to me 2003 2.4l with 110k miles. The service records did not indicate that the valves clearances were ever checked.
    My #2 exhaust valves were both at 9 mils (spec is 10-14 mils) and both my #4 intake valves were at 6 mils (spec is 6-10 mils). So I replaced the shims on these 4 valves to get 11 mils on the exhaust and 9 mils on the intake valves. All the other valves were in the middle of the specified clearance range.
    I thought I would pass on what I learned along the way:
    The service manual for my truck says that the valves should be checked every 60k.
    Most of the factory installed shims have a 0.01 mm (0.4 mil) thickness increment. Check the valve adjustment charts in the FSM.
    The replacement shims are only sold in 0.05 mm (2.0 mil) thickness increments. So save those original shims in case you need to get in range with a thickness that is no longer available.
    Dealers charge about $7 per shim with the on-line 30% discount. The bend over counter price can be double that if you are lucky. Most local to me dealers did not have the shims in stock, so plan ahead for truck down time.
    These guys sell the shims for $5 each, but you have to buy 4 at a time:
    http://www.cylinderheadsupply.com/valve-clearance-discs-28mm.html
    They also sell a tool you can use to lap your existing shims down to size.
    My machinist friends don't have a problem with lapping shims because the case hardening is much thicker than a couple of mils. But they say that lapping a mil of hardened steel will require a lot of elbow grease. If you go this way, they recommended placing the lapped side down so the un-lapped side interfaces with the cam lobe.
    I did not remove the cams and would not do so even if I had to replace all 16 shims! I found a great tool on You Tube that makes it very easy to push the valve bucket down even for the cylinders near the fire wall:
    Motion Pro 08-0018
    I still used the wedge from the Schley Products 88250 valve adjusting tool kit, but the pliers were too big and didn’t press the bucket down far enough without a struggle. To each his own.
    This is a precision operation so use good quality measuring instruments and make sure they are accurate.
    My Starrett dial calipers were not good enough because they only have 0.5 mil resolution. My Mitutoyo micrometer has 0.05 mil accuracy and resolution so it is good enough. My feeler gauge set agrees perfectly with my Mitutoyo micrometer, but would not agree with my Starrett calipers.
    So check your feeler gauges against your micrometer. I found the Toyota shims were dead nuts so your micrometer should agree with them too.
    Really if you cannot get the micrometer, feeler gauges and shims all on the same page, please buy better tools before attempting this project.
    EJPHI
    1997tacomav6 likes this.
  5. Jan 11, 2016 at 10:56 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Would be curious to know how many here have adjusted the valves on a 2nd Gen Tacoma V6 1GR-FE engine and at what mileage this took place?
  6. Dec 20, 2020 at 2:10 PM
    caliaska
    caliaska New Member
    2000 Silver Tacoma SR5
    Hi davidch, I hope you’re still active here and if anyone else who can answer my question with valve adjusting. So I have a 2000 Toyota Tacoma 2.4l 2rz-fe at 281k miles, I’m currently adjusting the valves because I have a cylinder 1 misfire (I have checked for vacuum leaks, replaced vacuum hoses, fuel filter etc.). I’ve measure the intake side for cylinder 1 and both valves are in spec; however, the exhaust side for cylinder 1 is too low. The back valve measurement for cylinder 1 is .004 inch while the front valve measurement is not available, even at .0015 inch that does not go through. So I know I’ll have to measure the shims (I have a micrometer) but should I also think about replacing the buckets? What else should I look into before replacing the shims now that I have the valve cover off?
    Thank you for any helpful feedback. I greatly appreciate it.
  7. Dec 20, 2020 at 2:15 PM
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    If you have valve noise at 84k take it to Toyota for an evaluation. Also don't use octane fuel rating higher than what is required. The ECU, catalyst system will work overtime adjusting for th octane change it's expecting.
  8. Dec 20, 2020 at 2:28 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    This is a Second Gen forum, as well... So maybe check the First Gen forums for answers on pre-2005 engines? I was under the impression that the 4.0 V-6 has self-adjusting valves or they need none?
  9. Dec 20, 2020 at 2:36 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    That is incorrect. The 4.0 liter 1GR-FE engine does not have self adjusting valves lifters.
    The 4 cylinder 2TR-FE does have hydraulic lash adjusters however.
    2TR > 1GR!
    :thumbsup:
  10. Dec 20, 2020 at 2:38 PM
    Gen2Tacoma
    Gen2Tacoma A Question Asked is an Answer Learned!
    North East Atlanta
    You Sir have the Taco tick as we all do! It's probably not the valves you are hearing!
  11. Dec 20, 2020 at 2:40 PM
    Bishop84
    Bishop84 Well-Known Member
    When its time for cylinder head gaskets.
  12. Dec 21, 2020 at 6:13 AM
    David K
    Can you expand on this, please? I have had all the servings performed by Toyota on schedule while the truck was under warranty and have since (now a 10-year-old truck) had an independent, Toyota certified mechanic perform them. Not once did "valve adjustment" get mentioned... So, what are the facts?
  13. Dec 21, 2020 at 4:50 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Well the simple facts are just as I stated:
    I am not responsible for what your mechanic(s) have or have not told you. Granted the Toyota Engines rarely "need" to have the valves lash "adjusted". The 1GR not having hydraulic adjusters is one reason they are noisy.
    TireFire likes this.
  14. Dec 22, 2020 at 12:56 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Pretty sure all Toyotas since the late 1980s or early 1990s have hydraulic tappets and don't require adjustment.
    When they eventually do need adjustment, you would rebuild the engine or just sell the vehicle.
    EDIT: It's very hard to believe (and understand why) Toyota would design a modern engine without hydraulic adjustment. The 4.0 is not a racing engine and the specific output is not very high.
  15. Dec 22, 2020 at 1:01 PM
    #35
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    :annoyed:
    Y'all should look at dates, and how this thread was revived.
  16. Dec 22, 2020 at 1:07 PM
    #36
    DGXR
    Friend
    Sacramento, CA
    OMG an old thread, this is a serious problem.
  17. Dec 22, 2020 at 1:09 PM
    #37
    Lester Lugnut
    See post #29
    DGXR[QUOTED] likes this.
  18. Dec 22, 2020 at 2:06 PM
    #38
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Jimmy already answered your question but FWIW (maybe not much, ha!) I recently checked mine at 198k when I installed new exhaust cam gears with 3 more degrees of retard which @mightytacoman sells. Valve clearance was still in the middle of the range.
    David K[QUOTED], EdgemanVA and Jimmyh like this.
  19. Dec 23, 2020 at 1:52 PM
    #39
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    I took my upper end apart to replace springs and install my upgraded camshafts last fall. This was at under 100k miles.
    I checked the clearances on the stock buckets/camshafts and they were exactly at stock tolerance. Exactly. Meaning like, no wear at all. I imagine I could have gone until the heat death of the Universe without having to adjust them.
    David K and TireFire like this.
