Valve "buckets" ?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Just some guy, Mar 27, 2023.
  1. Apr 30, 2023 at 1:15 PM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    Shouldn't make much difference. He also fabricates a new butterfly valve to seal properly (like yours isn't in the picture). The amount he bores out is pretty minimal (like a couple thousandths of an inch or so)
  2. May 15, 2023 at 1:51 PM
    Just some guy
    Just some guy [OP] Member
    Damin
    335k plus
    Hey guys.. still working this throttle body issue.. found one said to be from a 96 man trans cruise control. Picked it up locally, but the TPS sensor was different.
    Found one on EBAY said to be from a 98 prerunner, auto trans. All looks exactly the same. IAC and TPS connectors all match...
    Im getting mixed opinions on wheather it will work. Some say it has to match man trans - man trans... some say if fits, it will work.
    All n all im just trying to keep it on the road so i can send mine in for repair. Butvim about to just buy a new one, this is getting silly
  3. May 15, 2023 at 2:06 PM
    Just some guy
    Damin
    335k plus
    One more thing.. now that i cleand my engine from all the leaky VC, head and timing job. Found a presumed rear main seal leak thats causing my clutch to go to S#!T.. thats a real thing? Thanks for the help and ifo
  4. May 15, 2023 at 3:50 PM
    hessian42
    hessian42 Well-Known Member
    Max
    I did this when doing a valve job on my 3.4 but after measuring found that 70% of the shims i got from random yotas were 2.55-2.60 for some reason. All from 3 diff cars
  5. May 15, 2023 at 4:45 PM
    Red_03Taco
    Jerad
    Bummer. I must've gotten lucky in that case, because I got a pretty wide assortment out of just one 4runner
