Valve clatter and smoke...
Discussion in '1st Gen. Tacomas' started by Teflonboy, Jan 8, 2012.
  1. Jan 8, 2012 at 1:57 PM
    Teflonboy
    Teflonboy [OP] New Member
    Sherman Oaks,CA
    02 Toyota Tacoma Pre Runner
    Two days ago I started my truck and could hear clicking noise from the valve cover area, I was less than a 1/2 mile from home so I took it home and parked.
    Following morning would turn over but not start, leaked coolant from around water pump until system was drained.
    Any ideas?
    Thanks.
    Vehicle: 02 Tacoma Pre Runner
    Engine:V6
    Mileage:87,000
  2. Jan 8, 2012 at 9:58 PM
    300k96Tacoma
    300k96Tacoma Well-Known Member
    Weaverville NC
    96 Reg. cab 4x4 Tacoma
    Stock-300k miles
    im going to guess timing belt is loose and needs changed, may have bent the valves or something
  3. Jan 23, 2012 at 1:32 PM
    Teflonboy
    Sherman Oaks,CA
    Okay, thanks.
  4. Feb 8, 2012 at 11:54 AM
    Teflonboy
    Sherman Oaks,CA
    Update:
    Timing belt was fried which caused water pump to fail hence the smoke and valve clatter.
    Also found out that body shop had missed the fact the radiator was bent from last December after my truck was hit while parked.
    Bottom line I brought parts to Body Shop, Timing Belt,Water Pump,Drive Belts,Thermostat, they replaced at no cost.
    The timing belt looked like it had been cooked on a grill, melted rubber on the top of the belt etc.
    My cost for parts was $170.00
    They also paid for radiator, cross member repair and splash shield repair at no cost all things that they had missed before. The shop was willing to bend over backwards due to the fact they are a USAA approved shop and don't want to lose that status.
  5. Feb 11, 2012 at 2:36 PM
    300k96Tacoma
    Weaverville NC
    Stock-300k miles
    Well thats good that they are fixing it for you!
