valve cover bolts
Discussion in '4 Cylinder' started by hornytoad, Jul 4, 2012.
  1. Jul 4, 2012 at 2:35 PM
    hornytoad
    hornytoad [OP] fisherman
    west texas
    96 tacoma sr5 4x4
    does anyone know the torque specs for the valve cover bolts .i have a 96 with 4cyl 2.7 3rz-fe iv got a oil leak from the valve cover gasket and want to replace the gasket.thanx in advance
  2. Jul 4, 2012 at 2:44 PM
    goomba
    goomba It is a Fluid Situation
    Josh
    San Antonio Fl
    96 White Ex. Cab Tacoma TRD 4X4
    3" lift Up front(Donahoe Racing ext. travel coil overs, Camburg UCA's), 1.5-2" lift in the back(aal and some billy 10" stroke short bodies), Bushwhacker Cut-Out fender flairs, 16"x10" Procomp Street locks, and 305/70 Procomp X-Terrains.
    I am prety sure it is 13ft. lbs. let me check in my haynes manual
  3. Jul 4, 2012 at 2:49 PM
    goomba
    Josh
    San Antonio Fl
    Sorry, It is 15 ft. lbs. And you do not have to worry about torque pattern.
  4. Jul 4, 2012 at 3:36 PM
    hornytoad
    west texas
    96 tacoma sr5 4x4
    thanx goomba that was quick. now i can replace the gasket
  5. Jul 4, 2012 at 4:09 PM
    goomba
    Josh
    San Antonio Fl
    No problem. If you need any other specs, or like info on how to do stuff I have that manual and will be glad to help. Just shoot me a pm.
  6. Jul 4, 2012 at 5:34 PM
    Ga tacoguy
    Ga tacoguy Well-Known Member
    Rudy
    Augusta Ga.
    Extended cab Base model 4 cyl
    Tailgate mod, horn mod,storage door mod
    :) I believe your torque setting for the 4 bolts that hold the valve cover on are a little high. If there are just four nuts to torque on the top of the motor, then the torque settings are for 52 INCH Pounds, not Pound feet. I think the setting of 15 pounds will be too much for the valve cover and it may damage the bolts. I could only find a source that shows a 93 with a 3 RZ-FE engine rebuild and it show the settings. Here is a link to the page. http://www.ncttora.com/fsm/1993/engine/7cylinder.pdf
    Most valve covers that I have done, require the use of Inch/pounds settings and not foot/ Pound which would put a lot of torque on the cover and the bolts. Good Luck...
  7. Jul 4, 2012 at 8:06 PM
    goomba
    Josh
    San Antonio Fl
    You have a 4 cyl engine Ga tacoguy(thats what it says on ur profile), are there not 10 bolts holding down your valve cover? And the head and valve cover is the same on both 4 cyl engines(2.4 and 2.7), just not the internals. The reason I ask is because you said there are only 4 bolts, and from what I remember there are 10 bolts. and that is what my book says.
    EDIT: NVM you have a 2nd gen :(
  8. Jul 5, 2012 at 2:44 PM
    hornytoad
    west texas
    96 tacoma sr5 4x4
    my valve cover has 10 bolts.swaped out the gasket last night took me 30min.after i took off the cover i realized my torque wrench is broken so i just tightened the bolts hand tight then another 90degrees.i started it and idled the truck for 10min and no leaks.ill go back in next week and check for leaks.thanx goomba for the quick info
  9. Jan 13, 2016 at 1:18 AM
    DukesTaco
    DukesTaco Well-Known Member
    AZ
    2nd Gen Double cab Pre Runner
    Not 15 ft lbs. It's more like 60 to 80 inch lbs. If you try 15 ftlbs make sure to have some extra valve cover bolt washers.
  10. Feb 13, 2016 at 2:27 PM
    h18w777
    h18w777 New Member
    That is RIGHT! My truck is down right now after trying to pull these bolts to 15. That broke the valve cover. $300 to replace along with $100 overnight shipping. Elsewhere 53 INCH pounds is what is being suggested for these bolts.
    Use EXTREME care.
  11. Feb 9, 2017 at 4:10 AM
    Jdub89
    Jdub89 Active Member
    Justin
    Walterboro, SC
    2008 Toyota Tacoma access cab
    Leveling kit 33s Snorkel
    2008 2.7 taco here. Do y'all know the torque specs for valve cover bolts? Or maybe a website I can look at to get them?
  12. Feb 15, 2017 at 5:05 PM
    2.7taco
    2.7taco Well-Known Member
    Texas
    2005 Tan Tacoma Base 5 LUG: Beaten , abused and still running strong.
    Fat Bobs 2.75 lift and level with short AAL, 16x8 Level 8 Guardian Wheels, 245/75R16 Toyo Open Country ATII, custom trans shift kit(home made), Trans temp. and Vac gauge, URD fuel pump upgrade(going back to stock soon).
    On the 2TR-FE 2.7 I have gone just a bit over hand tight. Nothing wild but less than 18 ft lb. So far after 100k miles after the replacement all is holding up well. I do recommend starting in the center and working your way around in a clockwise pattern. It just ensures everything is tightened equally. The pattern is probably not required but is a "best work practice".
    Jdub89 likes this.
