Valve Cover Gasket Leak?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bustedflyrod, Nov 14, 2012.
  1. Nov 14, 2012 at 1:22 PM
    bustedflyrod
    bustedflyrod [OP] Member
    Missoula, MT
    '10 DCSB sport
    Hey guys!
    First post and I already need help...
    But seriously, did a search and came up empty.
    It seems my 2010 V6 with 50k miles has developed a small oil leak (seep maybe) from the passenger side valve cover in several spots. Wouldn't be at all concerned if the truck were a little older, but with the other side being so clean, I'd hate to let this go if the warranty will cover it.
    Any chance this is something the dealer would cover under warranty or am I being way too demanding?
    They practically laughed me out of the service department when I asked them to replace the fan motor that sounded like a banshee at 20k miles.
    Should I just tighten up the bolts and let it go?
  2. Nov 14, 2012 at 3:59 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    It should be covered under the power train warranty. Make them install a new gasket.
  3. Nov 14, 2012 at 9:47 PM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    Wipe it off and call it a day.
  4. Dec 7, 2012 at 10:42 PM
    Roccoaverto
    Roccoaverto Member
    Rocco
    Scranton, PA
    07 TRD SR5 Double Cab
    2007 4.O double cab . Just had this done on both sides today at 78,000 miles. It was covered by Toyota certified preowned warranty which goes to 100,000 miles. 3 year 36,000 is up for you but there maybe a TSB for this issue. It is an 8 hour job.
  5. Dec 7, 2012 at 10:50 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    HOLY CRAPPPPPPP AN 8 HOUR JOB?!?!?!?!?!?!!?!?! WHATTTTTTTT?!?!??!!??!!?! :eek::eek::eek::eek::eek::eek:
  6. Dec 8, 2012 at 12:41 AM
    AlaskanTaco
    AlaskanTaco Well-Known Member
    Anchorage Alaska
    09 sr5 acc cab tacoma
    That is not enough to be called a leak. With all the different metals that the motor is made of, and they all expand at different rates. There is going to be a little weeping. If I was the mechanic, I would clean it off and just tell you to leave it be.
  7. Dec 8, 2012 at 1:07 AM
    WATacoRider
    WATacoRider Well-Known Member
    TRD Sport 4x4
    There's a TSB for it and it's covered under the 5 year, 60K mile warranty.
    Do a search for timing leak.
  8. Dec 8, 2012 at 4:58 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Aluminum expands at the same rate bud. If its an all aluminum block it should all expand at the same rate. There should be no excuse for that leakage.
  9. Dec 8, 2012 at 5:05 PM
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
    The timing cover is a big job, the dealership refuses to do mine(that's a whole other story), but your problem is just the valve cover gasket, which is a pretty simple fix. Mine looks about like yours, and my timing cover is leaking. Since this is a fairly easy fix I doubt they will give you any lip about it. If they don't wanna do it, there is a write up on here that shows how to remove and reinstall the valve covers to paint them.
  10. Dec 8, 2012 at 5:08 PM
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
  11. Dec 8, 2012 at 5:13 PM
    Fienoma
    Fienoma Well-Known Member
    Hieu
    New Mexcio
    2007 double cab Off road 4x4
    BHLM, In bed lights mod, K&N intake,OEM bed extender....more to come?
    I believe you might have the labor hours mixed:eek:..8hours would be something timing chain replacement would run:(.. Alldata says replacing both driver and passenger side valve covers would run 2.1 hours labor.
    Jimmyh likes this.
  12. Dec 8, 2012 at 5:15 PM
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    My thoughts exactly, pulling valve covers isn't that hard.
  13. Dec 8, 2012 at 5:17 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    TSB is not free.
    The TSB is simply a notice to the service departments that "If customer complains about "X", we have found that "Y" is likely the cause"
    TSB is free under warranty, normal labor applies out of warranty, though the dealer does have some "good will" budget discretion to cover all or part of some repairs.
    But 8 hours for a VC gasket? Sounds extreme when I can do a Tundra 4.7 timing belt in 5 hours.
  14. Dec 8, 2012 at 5:51 PM
    seric007
    seric007 Well-Known Member
    mine does the same thing. took it in and they laughed "that's not a leak", whatever. when it bugs me enough I'll just buy a new dumb gasket and throw it in. cost less then the stupid 50$ "Certified used warranty" deductible anyway
  15. Dec 8, 2012 at 7:29 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    lets take a minute and soak this in. . . . .
    we are able to complain about seepage/ residue. i dont think there is another truck on the planet that has this kind of quality. i smile every time i crawl under my truck or pop the hood:) no leaks and im pretty sure the only residue i have is from my sloppy ass.
    i wouldn't worry OP. if it gets to where it runs, just buy both v/c seals and the intake. . . . good to go
  16. Dec 8, 2012 at 7:41 PM
    jimalan1989
    jimalan1989 Member
    Jimmy
    Columbus, MS
    2011 4x4 Double Cab Long Bed SR5
    NONE
    just did an alldata flat rate time for both valve cover gaskets on a 4.0l v6(since im a service tech i have access to it). pays 2.1hrs for that repair and to be honest its looks really easy to do on my 11 taco with a v6. try changing them on an older Mitsh. Montero....now thats a pain.
  17. Dec 8, 2012 at 7:41 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    +1
    Fucked up last oil change and cranked it up with the oil cap off.
    I did it intentionally... my cut-off M1 bottle was still screwed into the valve cover, figured it was enough to control the splashing and keep the fan from blowing it all over the place.
    I was wrong :eek:
  18. Dec 8, 2012 at 10:23 PM
    AlaskanTaco
    Anchorage Alaska
    These are not full aluminum engines. They use different types of metal for rigidity. Haven't you ever heard of aluminum alloy? This is nothing to worry about. So, if the whole engine is made up of "Aluminum" then why would you have a warped head, and then once you check the deck on the short block, there is no sign of light on the other side of the straight edge? Just saying, "If I was the mechanic, I would not do anything about it." I can also promise you the Toyota dealer is going to say the same thing. There is nothing to worry about. You aren't loosing any oil. That looks like nothing other then a little bit of PCV residue. If it was leaking 1. You would clearly see it. 2. You would more then likely have a Lean code setting off the check engine light.
  19. Dec 8, 2012 at 10:48 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I thought I read somewhere they were full aluminum engines. I guess I was wrong, but I myself wouldn't really care about this kind of situation happening to me.
  20. Dec 9, 2012 at 12:11 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    A tiny oil leak is not going to give you a lean code on the ECU.
    Lean or Rich codes are for too little ( Lean ) or too much ( Rich ) fuel to air ratio.
