Valve Cover Gasket Leak?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bustedflyrod, Nov 14, 2012.
  1. Dec 9, 2012 at 12:11 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    A tiny oil leak is not going to give you a lean code on the ECU.
    Lean or Rich codes are for too little ( Lean ) or too much ( Rich ) fuel to air ratio.
  2. Dec 9, 2012 at 12:22 AM
    12TRDTacoma
    12TRDTacoma Pulley Man ;)
    Roberto
    Concord, CA
    12 TRD Sport DCLB 4x4 Tacoma
    Supercharged
    ^^^ Agreed.
  3. Dec 9, 2012 at 12:50 AM
    AlaskanTaco
    AlaskanTaco Well-Known Member
    Anchorage Alaska
    09 sr5 acc cab tacoma
    You do understand that is the valve cover is leaking it MIGHT/may cause a lean code due to the outside air is entering the valve cover due to engine vacuum? Yes, I am fully aware of how stoichiometric efficiency works. The PCV is already a calculated into the ECM to allow the proper 14.7:1 AFR and or +-1. Just saying, I was a GM drivability for YEARS and still do work on the side. I am 100% ASE certified along with all of my GM certs and on top of that, I have my AAS degree in automotive. The GMASEP program will teach you a lot
  4. Dec 9, 2012 at 4:33 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    I cut my teeth on International and Detroit Diesel motors. What you have is NOT a leak...
    Howard
  5. Dec 9, 2012 at 5:42 AM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2007 AC TRD OFFROAD
    Hit it with some Gunk and a hose. It will be good as new.
  6. Dec 9, 2012 at 9:26 AM
    Failure2Comply
    Failure2Comply Well-Known Member
    Virginia, USA
    05 Access TRD/SR5 4x4
    NFab bars, bed mat, Weathertech mats.
    As stated, clean it up and keep an eye on things.
  7. Dec 9, 2012 at 10:28 AM
    06SR5canada
    06SR5canada Well-Known Member
    Saskatchewan
    06 dblcab SR5
    2ndary air filter removed, flowmaster 40
    I got the same seepage, same spot. My dad said just to crank the bolt a smidge
  8. Dec 9, 2012 at 11:05 AM
    CITY TACO
    CITY TACO Member
    Greater New Brunswick
    15 TRD Barcelona Red
    Had the same problem with my 2010, first dealer denied that it was leaking till I made them change the gasket. Got it back and the only thing that they did was to put some silicon where the leak was then to tell me that they had changed the gasket. Started seeping a month later so took it to another dealer who checked it out and found that the gasket was OK but where the timing cover meets the engine block the factory had not put enough sealant causing the seepage. They also noted that the gasket had not been replaced before ( fraud by the first dealer) and that there was some corrosion on the valve cover mating surface. Has not leaked since.
  9. Dec 9, 2012 at 4:15 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    You do understand that the valve cover is under pressure due to crankcase pressure. It is NOT going to introduce additional flow into the intake. Outside air isn't getting into the valve cover; Crankcase pressure is greater than Atmospheric pressure. Even if it did allow air into the valve cover ( which is not possible ) the PCV valve will only allow so much flow... You need some more certifications.
    You sir are wrong. Sorry to have to point this out in public, but ... :rolleyes:
    I have been working on cars since I was 15 years old, I'm nearly 58 now. That is my certification, real world experience.
  10. Dec 9, 2012 at 4:21 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    ^^wondering at which point air leaked into valvecover would enter and mix with combustion air myself. . . . . funny i've been using that nozzle on the valvecover as a fill point for oil. . . . . didn't know i would end up burning it all in the combustion chamber. surprised i havent thrown any codes. . . . thanks alaskan i better take it in and have them check my ecu. . . . . and tell me wear to fill with oil!
  11. Dec 9, 2012 at 4:28 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    What the hell are you talking about?
    Crankcase is the area below the pistons. You know where the oil pan etc... I said nothing about the combustion chamber. I think you got confused. :eek:
  12. Dec 9, 2012 at 4:41 PM
    92dlxman
    Kevin
    Visalia, CA
    lol scarcasm dude. i understood the debate was getting a/f codes based on valve-cover leakage. my point was that if additional air in the v/c made a difference all the way at the o2 sensors then, this is one shitty engine. that air (and hopefully oil) should never ever make it into combustion, therefore never effecting a/f readings in the exhaust
  13. Dec 9, 2012 at 4:45 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Sarcasm meter is broken at the moment. ;)
  14. Dec 9, 2012 at 4:52 PM
    92dlxman
    Kevin
    Visalia, CA
    lol yea and typing it never works very well.
    i was hoping alaskan would chime in and give me some information on what the oil splashing around in my v/c's might do to my a/f readings. . . (rolls eyes)
  15. Dec 9, 2012 at 9:04 PM
    #35
    AlaskanTaco
    Anchorage Alaska
    If that is the case jimmy, then why can you spray a can of brake clean onto a leaking valve cover, watch the RPM's jump, and also watch the O2 sensor go rich? The valve cover is till under vacuum. May not be at a 14 inch of merc. But, it is still a vacuum. I have done this for a while and I have ALL of my certs and occasionally go into the college as a sub in emissions and electrical classes. Sorry to point THIS out in public. ;)
  16. Dec 9, 2012 at 10:44 PM
    #36
    Jimmyh
    SC
    2012 Prerunner SR5
    " then why can you spray a can of brake clean onto a leaking valve cover, watch the RPM's jump, and also watch the O2 sensor go rich? "
    I have done this for an intake or vacuum hose leaks, which could also include a leak on the PCV Hose. Never for a valve cover leak, they are obvious and easy to locate. The PCV Meters the flow anyway.
    I do however agree that the intake pulls crankcase gases via the PCV System that is connected to the valve cover. The crankcase is normally under a slight pressure that will vary by the amount of combustion gases blowing by the rings. Remove the oil fill cap and drive it a few miles and get back with me after you get through cleaning up all the oil.
    I will also agree if you poked a hole in the valve cover as big as an ink pen it could possible cause a code and Idle Issues as well if the PCV Valve was stuck open. There is no way that a tiny little seepage or even a leak at the gasket is going to cause any type of Lean Code.
    You have done it for a while... that is funny. You are 25 years old... I have grease stains on my work clothes older than that.
    I'm done.
  17. Dec 9, 2012 at 11:45 PM
    #37
    12TRDTacoma
    Roberto
    Concord, CA
    Supercharged
    ASE doesn't mean dick, all it means is that you can pass some fucking tests. I trust the guy who has had real life experience under the hood vs. some test jockey anyday, the problem is that ASE certifies anyone and that includes a person who has never been under the hood in their life and call them good to go, that's not how it should be.
    Anyways, The maximum allowable lean or rich deviation from stochiometric is +-2 in the state of kalifornia (and you know how anal the smog nazis are here). I have NEVER seen a leaking valve cover gasket, more specifically one that looks like OP's cause codes, driveability issues etc. etc.
  18. Dec 10, 2012 at 6:43 PM
    #38
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    But he's ASE... that's like graduating from MMI.
    Kid spends $20k on book-learning and then tries to tell a 60 y/o biker that everything he knows about Harleys is wrong.
    Seriously... when I see ASE, I run.
  19. Dec 13, 2012 at 8:29 PM
    #39
    Jimmyh
    SC
    2012 Prerunner SR5
    MMI
    :eek: Run!!!
  20. Dec 13, 2012 at 8:36 PM
    #40
    ProForce
    ProForce IG @proforce.overland OB#5411
    Anthony
    SoCal-Ontario
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    Mine didnt look half that bad and the dealer fixed mine. They said its covered by the 5yr 50k power train warranty and I have 44k on mine. They put a UV dye and tools me to come back after 200 miles. When I came back they ordered the seal and had the job done in about 6 hours. They say it takes that long because they wont even touch the truck for several hours until it cools down. Its not actually a very time consuming job. And yes, it is a TSB
