Valve Cover gasket leak
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ortacoma10, Mar 26, 2025.
  1. Mar 26, 2025 at 6:49 AM
    Ortacoma10
    Ortacoma10 [OP] Well-Known Member
    2010 Tacoma Trd Off-road 4x4
    When changing spark plugs yesterday as my preventative maintenance every 30k I notice slight oil in the passenger side of the coils of my 4.0. Did my research and spoke with my local mechanic and came to terms it’s the valve cover gasket. He will be replacing this Friday doing both while he’s at it. Is this a common issue on the 2nd gen 4.0’s? I check my oil a couple times a week and have never noticed low oil
  2. Mar 26, 2025 at 7:33 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    It's relatively common on many engines that have spark plug tube seals for oil to leak into them when they get older and the seals get hard, wouldn't be enough for it to be low on oil but it will eventually cause misfires as the coil boots swell from being immersed in oil.
    Ortacoma10[OP] likes this.
  3. Mar 26, 2025 at 7:39 AM
    Ortacoma10
    Ok makes sense. So I take it its definitely the valve cover gasket tho correct?
  4. Mar 26, 2025 at 9:00 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The valve cover gasket and the spark plug "tube" seals come as a set and connected together.
    To get to the seals the valve cover needs to be removed.
    HWI, Ortacoma10[QUOTED][OP] and Dm93 like this.
  5. Mar 26, 2025 at 9:16 AM
    Rougarou680
    Rougarou680 Swamp Lurker
    Lousyana
    2006 Tacoma 4.0 Prerunner, 2013 & 2014 Tacoma 4WD 4.0L
    Leveling kit, hydro dipped rims & skid plate on 2013, 6” pro comp lift & color matched rims on 2006.
    I just had same issue when I replaced spark plugs. The valve cover bolt closest to it wasn’t torqued to spec when I checked it. Hopefully that’s all mine was.
  6. Mar 26, 2025 at 10:16 AM
    Ortacoma10
    Sweet yeah my local guy ordered the whole kit to do it all. Like I said it’s just passenger side leaking but he’s doing it all while it’s removed.
    I’ve heard it’s a fairly simple task, just don’t have the time to tackle this one
    Jimmyh[QUOTED] likes this.
  7. Mar 27, 2025 at 12:36 PM
    TacoTuesday1
    SD CA
    A valve cover gasket wearing out is not an issue. It is supposed to. VCG is a wear item with a lifespan.
