Valve cover gasket replacement. Engine won’t stay on.
Discussion in '1st Gen. Tacomas (1995-2004)' started by 96tacomzn, Aug 5, 2023.
  1. Aug 5, 2023 at 6:47 AM
    96tacomzn
    96tacomzn [OP] New Member
    Mark
    1996 LX Tacoma
    I just want to start off by saying I’m new to this, my friend and I noticed oil leaks coming from the valve cover. He suggested it was a bad valve cover gasket and after a few hours of taking stuff apart to get to it, he was right! So we fixed and then started putting stuff together. That’s where the problems started. I want to make it known I should’ve taken A LOT more pictures then I actually did. The process was more of a “trying to figure out” where each hose and proper screws went with the limited amount of pictures. We got everything back together and we had a long screw left over. One white plug with no where to go(found out in a separate forum that it’s a temperature gauge) and a brownish orange plug behind the intake that won’t fully click in.
    we called it a day so I can do more research before I take it apart again so I thought I would ask around! Safe to say there’s no more oil leak though!
    Have pictures for reference if anyone need to see what I’m talking about.
  2. Aug 5, 2023 at 11:52 AM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Bivouac and 96tacomzn[OP] like this.
  3. Aug 5, 2023 at 12:14 PM
    96tacomzn
    Mark
    1996 LX Tacoma
    Thank you, will take a look at the thread and videos once I’m off work
  4. Aug 5, 2023 at 3:06 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Since the engine starts and shuts off .
    Did this trip the MIL and did you pull the codes ?
    Sounds like something is not connected ECM ground is not making a good connection.
    96tacomzn[QUOTED][OP] and Sklar like this.
  5. Aug 10, 2023 at 6:33 PM
    96tacomzn
    Mark
    1996 LX Tacoma
    Sorry again for being fairly new but what do you mean by MIL and pull the codes how so. I also do want to mention that the engine seemed like it was struggling a bit
  6. Aug 10, 2023 at 6:37 PM
    96tacomzn
    Mark
    1996 LX Tacoma
    Area51Runner[QUOTED] likes this.
  7. Aug 10, 2023 at 7:38 PM
    Area51Runner
    The check engine warning light on the instrument cluster. If it's on, you can head over to the local parts store and they should be willing to check it for free with their code reader. A code reader will produce an error code and you then can search google using that error code or post here. It will get you started on the path of resolving any outstanding issue the computer has detected.
    You can go as simple as this:
    https://www.amazon.com/VDIAGTOOL-Scanner-Diagnostic-Readiness-Protocol/dp/B0BY1TS725/
    or a version which connects to your phone via Bluetooth and utilizes an app
    https://www.amazon.com/Scanner-Vehicle-Adapter-Wireless-Diagnostic/dp/B076FRK5BT/
    Android App: https://play.google.com/store/apps/details?id=org.prowl.torquefree&pcampaignid=web_share
    There is a similar version for Apple, I don't have the link handy. Search it.
    Bivouac likes this.
