valve cover gasket
Discussion in '1st Gen. Tacomas (1995-2004)' started by 04Prerunnertaco, Feb 18, 2014.
  1. Feb 18, 2014 at 4:18 PM
    04Prerunnertaco
    04Prerunnertaco [OP] Well-Known Member
    Canton, GA
    2017 silver sky trd 4x2
    Has anyone done it on the prerunner ? I think I need to change mine. Anyone happen to know the part number ?
  2. Feb 18, 2014 at 4:19 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    What motor first?
  3. Feb 18, 2014 at 4:29 PM
    04Prerunnertaco
    Canton, GA
    Sorry that would help. 3.4 the 5VZFE
  4. Feb 18, 2014 at 6:55 PM
    jgilbreath
    jgilbreath Well-Known Member
    Kerrville, TX
    99 Tacoma PreRunner
    Husky floor liners, SAWs 2.0
    The gasket is 11213-62020. Its a good idea to do a few other things while you are in there.
    2 cam plugs
    6 spark plug tube gaskets
    16 valve cover grommets (basically washers for valve cover bolts)
    PCV valve and grommet
    Throttle body gasket
    You will need some FIPG sealant for around the cam plugs
    Also clean the throttle body, plenum, and two plenum gaskets while everything is apart.
  5. Feb 18, 2014 at 8:12 PM
    04Prerunnertaco
    Canton, GA
    great thanks.Where is a good place online to purchase toyota parts? I know a few spots but maybe something new ? Thanks again.
  6. Feb 18, 2014 at 8:16 PM
    04Prerunnertaco
    Canton, GA
    Also should i replace the plenum gaskets as well? i heard i don't really need too but i am wondering if i should.
  7. Feb 18, 2014 at 8:57 PM
    2000GTacoma
    Snow Hill NC
  8. Feb 18, 2014 at 9:23 PM
    kigmob
    kigmob Well-Known Member
    James
    New Orleans
    97 TRD S/C 4x4 V6 5spd
    ICON/TC TRD Supercharger URD 2.2 and 7th
    I would also re pack the semi circles with FIPG. The permatex ultra grey rtv is the equivalent of the Toyota FIPG. There are 2 semi circles on each head. One in the front and one in the back. I would buy new plenum gaskets as well. Also changes the plugs while you're in there. Super easy with everything off. Also, when you clean the TB, I would take off the IAC Valve and clean it as well. Just cleaning the TB doesn't clean the IAC. Other than that remember where all you vacuum lines go and make sure you torque everything down correctly. I just did this like 2 months ago on my 97.
  9. Feb 19, 2014 at 4:49 AM
    Rons01TRD
    Rons01TRD Well-Known Member
    Ron
    Virginia Beach, VA
    2007 4Runner 4WD
    I went ahead and painted everything when I did mine.
  10. Feb 19, 2014 at 5:17 AM
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    Re gasketed a whole intake system once using "The Right Stuff" from Permatex and some old gaskets that came off. Comes in a black cheeze whiz can and is spendy. Vicious to remove and it doesn't care so much about clean surfaces. it sticks,seals and you can gap fill with it,,but its a pain to deal with after cured. Have pulled 26 inches of vacuum on it and the stuff didn't move. I think it's concrete in a can.
  11. Feb 19, 2014 at 6:16 AM
    Rons01TRD
    Ron
    Virginia Beach, VA
    2007 4Runner 4WD
    Factory Toyota intake gaskets were only $11 each, that's what I used, no sealing or messy cleanup.
  12. Mar 22, 2014 at 10:04 AM
    Corn
    Corn Well-Known Member
    NC
    00' Tacoma 4x4 ext. cab 3.4 ltr
    Fog lights, suspension, wheels
    Is the consensus to not use any sealant on the corners for valve cover gaskets? I was curious what the Hayne's manual would say about this. If it's a Toyota gasket from the dealer would you have to use sealant at the 90s?
