Valve cover gasket
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Beerline123, Mar 14, 2020.
  1. Mar 14, 2020 at 8:17 PM
    Beerline123
    Beerline123 [OP] Well-Known Member
    07 Tacoma access 4x4
    Do you need to take off intake manifold for passengers side. Tia
    nudavinci64 likes this.
  2. Mar 14, 2020 at 8:18 PM
    Bishop84
    Bishop84 Well-Known Member
    Nope, ez pz. Clean the throttle plate and air flow meter while you're in there!
    420taco, b_r_o and 07tacomatoy like this.
  3. Mar 14, 2020 at 8:41 PM
    Beerline123
    Thanks for your advice you give to the board. I know your an experienced toyota mechanic much appreciated.
  4. Mar 14, 2020 at 8:47 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Funny I just asked this question in another thread.
    so do you just move it to the side? I’m swapping cam gears and want to give it a good cleaning. says remove 12 bolts seems to be the last ones here.
  5. Mar 14, 2020 at 10:01 PM
    Bishop84
    (2012+) The air valves just unbolt, there's a hidden 12mm below it bolted to the head thats a bastard.
    I also unbolt the studs with the torx bit to help remove them quicker.
    While they are out clean them with WD40 to remove any possible water and carbon build up.
    Don't worry about the metal exhaust gaskets on the air valves as they are re-useable.
    b_r_o likes this.
  6. Mar 14, 2020 at 10:30 PM
    nudavinci64
    Robert
    Good looking out. I was trying to figure out how to get that thing off. The hidden 12mm makes sense. Also good to know it unbolts and comes off. I wasn't sure since every how to has been 05-11. Thats the idea when they are off, install new 3 degree cam gears and give the covers a good once over with some cleaner.
    Also good tip unbolting the studs. With the limited room that will make it easier than wiggling it back and forth.
