Valve Cover Gasket
Discussion in '2nd Gen. Tacomas (2005-2015)' started by emt49126, Feb 2, 2024.
  1. Feb 2, 2024 at 3:13 PM
    emt49126
    emt49126 [OP] Active Member
    Rodney
    Kentucky
    Tacoma
    I have a 07 Tacoma 2.4l with 180,651 miles on it. I have already changed the valve cover gasket in Jan. 2021 with mileage of 154,404. Has anyone had to change one out again with it having less 30,000 miles on it? The leak is in the same place that it was the first time. I am not going to do the changing myself this time, due to not wanting to hurt more for days to follow. Just curios is all and any thoughts on this. I use felt-pro gasket when I changed it out and used sealant at the housing breaks/cracks.
  2. Feb 2, 2024 at 4:13 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Sure they can, they are more likely to leak if you don't use RTV in correct places.
    And some guys will say a torque wrench isn't needed, if you get the cover bolts too tight they can distort the gasket.
  3. Feb 2, 2024 at 4:16 PM
    Bishop84
    Bishop84 Well-Known Member
    Other guys will say check pcv valve for proper operation. High pressure causes recurring leaks.
    TnShooter likes this.
  4. Feb 2, 2024 at 4:17 PM
    TacoTuesday1
    SD CA
    folks who work on cars do this:
    -avoid FelPro because it’s garbage
    -put good RTV where needed
    -torque bolts to spec, replace if one time use
    -liquid non drying sealer where useful
    -verify PCV system in working order
    did VCG with OEM. Years and many miles later no leaks.
  5. Feb 2, 2024 at 10:46 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Where's it leaking? Do you have a pic?
