Valve cover leaks
Discussion in '1st Gen. Tacomas (1995-2004)' started by 98 TACO, Mar 31, 2016.
  1. Mar 31, 2016 at 3:30 PM
    98 TACO
    98 TACO [OP] Member
    USA
    98tacoma
    Fender flares wheels
    How hard is it to change a valve cover gasket on a 98 Tacoma 4 cy
  2. Mar 31, 2016 at 4:30 PM
    2stroketrush
    2stroketrush Well-Known Member
    Tyler Addison Rush
    Baltimore
    Built 97 ExtraCab
    Overland Purpose Built 97 going on 190K.
    very easy, just don't over torque
  3. Apr 1, 2016 at 3:37 AM
    98 TACO
    98 TACO [OP] Member
    USA
    98tacoma
    Thanks
  4. Apr 1, 2016 at 8:14 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    On my 1987 2.7l motor, over-tightening the valve cover nuts resulted in noisy valves. That's because the cover nuts attached to threaded studs that were screwed into the cam hold-downs. Over-tightening the nuts would lift up the camshaft ever-so-slightly, causing additional clearance between the cam lobes and the valves.
    I believe that at some time later this method of securing the covers was changed to screws around the bottom lip of the cover that went into the head itself and not into the valve train components.
  5. Apr 1, 2016 at 4:52 PM
    98 TACO
    98 TACO [OP] Member
    USA
    98tacoma
    Thanks
