Valve gasket job gone wrong
Discussion in '1st Gen. Tacomas (1995-2004)' started by Knolly, Sep 11, 2019.
  1. Sep 11, 2019 at 5:51 PM
    Knolly
    Knolly [OP] Member
    Zach
    97 Tacoma
    I replaced my valve cover gaskets because they were leaking oil, after the job was done I was able to drive the truck and it ran good for a day. Now it idles alright but begins sputtering and shaking when I put it in gear. I have no clue what could be causing this, any ideas?
    Running Board Man likes this.
  2. Sep 11, 2019 at 5:59 PM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    Could be a loose spark plug wire
  3. Sep 11, 2019 at 6:04 PM
    Knolly
    Knolly [OP] Member
    Zach
    97 Tacoma
    I replaced spark plug wires because I ripped the metal bit out from inside the old ones while doing the job, and just checked them, and put fresh electrical grease on them. It didn't seem to help.
    GQ7227 likes this.
  4. Sep 11, 2019 at 8:49 PM
    MikeWH
    MikeWH Well-Known Member
    Colfax, CA
    1999 TRD 4x4 (x2)
    You forget to plug something back in? Maybe a vacuum line not reinstalled?
  5. Sep 11, 2019 at 8:57 PM
    Knolly
    Knolly [OP] Member
    Zach
    97 Tacoma
    I believe everything is connected properly, could a bad throttle position sensor cause a horribly rough idle when in gear?
  6. Sep 11, 2019 at 9:00 PM
    MikeWH
    Colfax, CA
    1999 TRD 4x4 (x2)
    In theory maybe. Can you use a scan tool to verify it reads correctly? Or get an OEM new one on eBay to try out.
  7. Sep 11, 2019 at 9:02 PM
    Rustytaco71
    Rustytaco71 Well-Known Member
    2018 4Runner
    I’d give a good cleaning to your mass air flow sensor. I’ve had numerous issues that were due to a dirty sensor and now that I know that it saves a lot of headache when trouble shooting.
    GQ7227 likes this.
  8. Sep 11, 2019 at 9:02 PM
    Knolly
    Knolly [OP] Member
    Zach
    97 Tacoma
    I'll pick one up tomorrow and see if it does the trick, I tried unplugging it and the truck had the same symptoms as when it was plugged in. If it isn't that I don't have another guess.
  9. Sep 11, 2019 at 9:10 PM
    Bishop84
    Bishop84 Well-Known Member
    If it idled before, its something you've done.
    Vacuum leak, incorrect spark plug wire routing etc.
    The TPS, or MAF won't fail simply overnight.
  10. Sep 11, 2019 at 9:10 PM
    Superman
    Superman Well-Known Member
    Joe
    Michigan
    2017 Quicksand TRD OR DCSB
    Current: Behind rear seat MOLLE panel Softopper Empyre grille insert MesoJDM ultimate red maps MesoJDM ultimate white dome Future: BajaRack roofrack/basket Mobtown bolt-on sliders Mobtown rear plate bumper Mobtown front plate bumper On-board air compressor Ditch lights LED headlights (blacked out) LED taillights (blacked out) LED yellow fog lights Bedrack over softopper Maxtrax
    I would look around the PCV valve or breather hoses
  11. Sep 11, 2019 at 9:19 PM
    tony2018
    tony2018 Well-Known Member
  12. Sep 11, 2019 at 9:25 PM
    Rujack
    Rujack Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    Get some carb cleaner and spray it around the vacuum lines. It’ll surge if it sucks it into the leaking line and you’ll know where to look. Worth $3 on a can.
  13. Sep 11, 2019 at 9:28 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Check the idle air control valve. I suspect if it's not operating properly that would cause issues once you shifted into gear.
  14. Sep 11, 2019 at 9:28 PM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    There is a little connector behind the driver side near the fuel pressure regulator. Did you plug that back in? If I remember correctly It’s small and hard to get to.
    EDIT: I’m not sure what the function of it is. Just a guess, it’s easy to miss.
  15. Sep 12, 2019 at 10:29 AM
    mateo_roberto
    mateo_roberto Well-Known Member
    Mateo
    San Diego, CA
    1995.5 Tijuana Teal 4x4
    Stock
    I did this job and was sure everything was reconnected vacuum wise. Sure enough I missed two after checking a few weeks later. Grab a beer and spend some time under the hood looking around.
  16. Sep 14, 2019 at 10:12 AM
    Knolly
    Knolly [OP] Member
    Zach
    97 Tacoma
    Hey guys, I basically redid the whole job and everything is connected properly. It's idling rough and I can smell gas if I let it idle for a little bit. This makes me think a cylinder isn't firing. What do you think?
    wilcam47 likes this.
  17. Sep 14, 2019 at 10:14 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    is there a Check engine light?
  18. Sep 14, 2019 at 10:15 AM
    Knolly
    Knolly [OP] Member
    Zach
    97 Tacoma
    What size socket do I need to get spark plugs out?
  19. Sep 14, 2019 at 10:19 AM
    Shortman5
    Supercharged TRD
    You need a spark plug socket with the rubber bit to grab the plug. Any auto parts store will have one.
  20. Sep 14, 2019 at 10:20 AM
    Knolly
    Knolly [OP] Member
    Zach
    97 Tacoma
    Yeah but they come in a couple of sizes, do you know which one the first gens take?
