Valve job or replace the engine?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Johnnyx51, Jan 9, 2017.
  1. Jan 18, 2017 at 10:23 AM
    #41
    1999RegCab
    1999RegCab Well-Known Member
    Cacti Land, AZ
    1999 Reg Cab, 2.7, 5 speed
    3-link SAS
    An engine that has a tendency to blow head gaskets can turn into an expensive ordeal....just sayin':p
  2. Jan 18, 2017 at 10:50 AM
    #42
    BThorson
    BThorson Well-Known Member
    Oregon
    2003 red Tacoma TRD 5speed
    3" toyotec coils, wheelers progressive leaf, bilstien 5100, pro comp wheels, 285/75r16 cooper st maxx, grey wire, weather tech, floor mats, bug deflector and rain guards, old man bed shell, tint
    I had the same truck but mine was a 1990 auto v6. I really wanted to swap in a manual and a 3.4. There is a company that will do this for you but it is expensive if I remember correctly about 4-5k. Also the 3.4 sits higher than the 3.0 so you need a hood scoop or a body lift. I ended up buying a 03 tacoma in manual. I will try to find the company that does it but if I were you I would see how bad the problem is first and try to keep the motor. If it is too bad bite the bullet sell and buy a tacoma.
  3. Jan 18, 2017 at 10:55 AM
    #43
    BThorson
    Oregon
  4. Jan 18, 2017 at 1:07 PM
    #44
    SAB_0010
    SAB_0010 Well-Known Member
    Seth
    1996 Tacoma 3.4l 5-speed
    All of you guys saying "swap in a 3.4!" aren't considering a whole lot. Most people aren't made out of money. You're going to end up spending as much if not more than what you can BUY a TACOMA for. OP, sell the truck, or keep it and just have the 3.0 fixed, but if you are hell bent on a 3.4 then you are much better off investing in a solid Tacoma with the 5vz already in it.
    BThorson likes this.
  5. Jan 18, 2017 at 5:22 PM
    #45
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    I thought the engine blew head gaskets because they were built with the defective head gaskets, not that the engine had a tendency to blow them. I'll read up on it a little bit.
  6. Jan 18, 2017 at 8:06 PM
    #46
    1999RegCab
    Cacti Land, AZ
    3-link SAS
    Well, i do not really know. All I know is that there's a long history of those engine blowing head gaskets even after they were replaced. There's some theories about there about whether or not many of those engines actually had some manufacturing inconsistencies. I don't really know. What I know is that a lot of people did not those engines at all because they were unreliable and anemic.
  7. Jan 18, 2017 at 8:42 PM
    #47
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
  8. Jan 18, 2017 at 8:43 PM
    #48
    herbertgerg
    herbertgerg Well-Known Member
    Gary
    1999 SR5 4x4 5spd Access Cab
    Its not as hard as it sounds if you buy the right parts. I did one on a 93 yota pickup with a 5 speed with a junkyard 3.4l and the wiring harness from ORS. Truck is still on the road. FWIW, also just rolled 400k on my 99 with a 2.7l. They're both super reliable motors. 3.4l is closer to 'plug and play' than the 2.7l for your application. We did lots of reading and parts hunting before the swap.
    BThorson[QUOTED] likes this.
  9. Jan 18, 2017 at 10:48 PM
    #49
    99SuperTaco4x4
    99SuperTaco4x4 Well-Known Member
    1999 3.4L V6 Tacoma, 4x4, TRD Supercharger
    No offense to OP, but if you didn't even know what vehicle you bought, engine swapping is not for you lol. I mean, unless you are seriously in love with the truck body you thought was a tacoma, it will likely be cheaper to sell your 94' pickup and buy an actual tacoma 95.5+ with the 3.4L engine already in there (and still spend less time and money on an engine swap done by someone else).
    My 0.02. Sorry to hear about your truck, hopefully it turns out to be a cheaper fix than you thought. good luck
  10. Jan 18, 2017 at 10:57 PM
    #50
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    The head gasket wasn't defective on the 3.0s they tended to overheat and blow the gasket near the #6 cyl due to poor design of the exhaust headers. A stronger head gasket and freshly milled heads was the bandaid fix toyota assigned to deal with an engine that truly needed better headers. With better headers there wouldn't be the tendency for it to build too much heat back there. Still an underperforming 3.0 V6 and the only single cam V6 toyota ever made but I suppose it could at least be dependable.
  11. Jan 18, 2017 at 11:45 PM
    #51
    BThorson
    Oregon
    For me it was just a factor of money. I decided to buy a 03 tacoma with a manual and the 3.4 I kept the 1990 for awhile after buying Tacoma too. I was just showing OP what will be involved. For him it will be easier to swap engine as I wanted to swap a manual into the 1990 along with 3.4 ;)
  12. Jan 19, 2017 at 5:24 PM
    #52
    1997tacomav6
    Denver
    Do yourself a favor and buy a 3.4 v6 motor as they last 500,000 if taken care of and DO NOT BUY A JAPANESE JBL motor was made for the Japan market.
    These engines you can find everywhere for sale brought over from Japan but you have NO idea of the miles, forget that they say they have 50, or 60, or 70,000 miles. For all you know your buying an engine with 200,000 miles. They have no idea or no proof of what any of the miles are on any of these engines.
    Find a wrecked trunk that has the engine in it 100,000 miles or so you can hear it running and you can do a carfax to get the true miles on the truck. You don't want to do an engine swap twice because of a bad engine you bought.
    GQ7227 likes this.
  13. Jan 20, 2017 at 3:34 PM
    #53
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    I dont think ive ever seen a Japanese vehicle (In/ from Japan) with over 200k miles myself. Theres nowhere there to drive unlike the great distances we have in the Americas. Which is why they have 50,60,70,000 Miles.
    GQ7227 likes this.
  14. Jan 20, 2017 at 3:47 PM
    #54
    Speedytech7
    They used to have a regulation that didn't allow a vehicle to be legally operated after 60,000. Because it is a small island, emissions and environmental protection are super important and apparently a study found that around then was the right time to discontinue use of a vehicle. With efficiency and emissions being improved I think that law has been lifted but theres still plenty of vehicles that it could still apply to and typically those are what we get engines from.
  15. Jan 20, 2017 at 7:23 PM
    #55
    1997tacomav6
    Denver
    That's a urban myth and not true from what I have read And have seen plenty of thread of people that bought one of these motors that was no good, also hear that
    because these were made for the Japanese market the emission setup is not the same as the USA engines is what my parts man at Toyota told me, anyway still you would be taking a gamble and who wants to replace an engine twice if it doesn't pan out, is a gamble
    http://www.superstreetonline.com/how-to/project-car/ssts-0664-buying-used-jdm-motors/
    http://www.city-data.com/forum/automotive/1469231-jdm-engines-generally-reliable-risky.html
    GQ7227 likes this.
