Valve lash inspection / adjustment on 4.0 V6?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Apex1, Dec 4, 2018.
  1. Dec 4, 2018 at 10:50 AM
    Apex1
    Apex1 [OP] Well-Known Member
    2011 DCSB TRD
    Did some searching on 4.0 valve adjustment and inspection procedure. I see a lot of chatter (pardon the pun) on the subject, but could not find an example of someone who actually went through the process. Checking seems about as easy as doing valve cover gaskets. Adjusting seems a bit harder as it requires cam shaft removal and bucket replacement.
    Has anyone actually checked their valve lash? If so what were the specs?
    Has anyone actually adjusted their valve lash? If so than you should get some sort of enthusiast mechanic award!
  2. Dec 4, 2018 at 11:03 AM
    Masshole_And_His_Taco
    Masshole_And_His_Taco PAHTS KEHD
    Northish South Shore MA
    Stick Shift Shit Brick
    Little bit of stuff.
    Sub'd for info
  3. Dec 4, 2018 at 1:23 PM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    Why do you feel the need to /check adjust valve lash?
  4. Dec 4, 2018 at 1:38 PM
    Apex1
    2011 DCSB TRD
    Well there are about 500 plus threads on the taco tick and various ticking and noisy engine complaints. Its common for these engines to be noisy but it is NOT universal. Some of these engines don't have the taco tick, some do. But the common theme is that there is no known cause or solution.
    Parallel that with the threads on valve adjustment. There are plenty of those (some are the same as the taco tick threads) too, and they usually end with the valve adjustment being unnecessary, complicated and or expensive. I was not able to find a single thread or post where someone actually checked the valves and reported their finding on a 4.0 V6. I am curious if anyone has looked into this.
    I have no idea whether I need to check or adjust my valves, at this point I am just doing research.
  5. Dec 4, 2018 at 1:41 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    2005 black sand pearl TRD OR
    stickers and sticker accessory's
    if you think you need valves adjusted sub 250k miles you don't take your truck to redline enough.
  6. Dec 4, 2018 at 1:42 PM
    Longtech
    Longtech i fcked up and bought a 2wd
    Long
    Santa Ana, CA
    15' OR 2WD
    I wouldnt bother with inspecting it unless there is really loud valvetrain noise or rough idling. Aint broke. Drive on!!
  7. Dec 4, 2018 at 1:59 PM
    Tacologist
    Tacologist Well-Known Member
    Bob
    Tenessee
    05 Double Cab Shortbed
    Rear leaf suspension. Home done tailgate re-inforcement.
    Shim under bucket valves, like the ones in the Tacoma, often get tighter with mileage and age. It is possible that Toyota knows this and purposely adjusts the valves looser to the high end of spec; knowing full well that few if any will ever attempt to check or adjust them. This is where the famous "tic" may be coming from.
  8. Dec 4, 2018 at 2:09 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    ^^^^^^^^^^^ This.
    Or get a 4 banger that has hydraulic lash adjusters. :)
    12TRDTacoma and Lester Lugnut like this.
  9. Dec 4, 2018 at 2:27 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    '15 Tacoma PreRunner V6 SR5 Auto
    May be the reason why that fella in North Carolina got 1.2 millions miles on his Tacoma - his is a 2.7L
    b_r_o and Jimmyh like this.
  10. Dec 4, 2018 at 2:36 PM
    12TRDTacoma
    12TRDTacoma Pulley Man ;)
    Roberto
    Concord, CA
    12 TRD Sport DCLB 4x4 Tacoma
    Supercharged
    The best way to mask the Taco Tick is to take it to redline more often! :D
    BassAckwards likes this.
  11. Dec 4, 2018 at 2:37 PM
    wheeliest
    wheeliest NOT A SENSITIVE PUSS
    Json
    TMPE AZ
    05-DCSB-4X4-V6-SR5-SPORT
    NO SWAYBAR, Spacer lift with dirty4's
    yes, valves out of adjustment get quiet (tight). the 4L is a metal engine with metal parts moving in it.. sometimes when metal touchs metal it makes noise. lol
  12. Dec 4, 2018 at 2:39 PM
    Fullboogie
    Dave
    Houston
    I'd say the vast majority of "taco tick" inquires are from new Toyota owners who are not used to the injector noise. These engines really are noisy compared to other OHC 6 and 8 cylinders out there. And being an OHC engine, unless either the block or heads are decked, there simply is not a need to "adjust" valve lash.
  13. Dec 4, 2018 at 2:57 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    OK here is the deal on shimmed valve adjustment the old 3L had issues it was valve stretch yes hammering into the valve seats stretched the valves over time so the clearance became less but techknowledge moved on now all of the modern parts ware pretty much equally so the clearance should remain the same over the life of the engine. If you want to have at it there are 24 of them so have fun be sure to have a large box of shims and a good digital micrometer!
    gearcruncher likes this.
  14. Dec 4, 2018 at 3:41 PM
    dipstiktaco
    dipstiktaco Well-Known Member
    canada
    2006 TRD off road access cab auto URD supercharged
    He's replaced the engine in that time
  15. Dec 4, 2018 at 3:52 PM
    Lester Lugnut
    Yeah...at around 800,000 miles. Added another 400,000 since that.
  16. Dec 4, 2018 at 5:39 PM
    dipstiktaco
    canada
    So the engine only ever had 800,000 on it not 1.2mil
  17. Dec 4, 2018 at 5:42 PM
    Lester Lugnut
    Go watch the video
  18. Dec 4, 2018 at 6:10 PM
    Apex1
    2011 DCSB TRD
    FYI there are no shims in the 4.0 v6 just buckets. Buckets come in a variety of heights, pick the one that facilitates the correct lash.
  19. Dec 4, 2018 at 6:19 PM
    b_r_o
    b_r_o fresh cakes
    Alex
    WA
    2015 DCLB
    I have not done any
    I think the shim is on top of the bucket
  20. Dec 4, 2018 at 6:35 PM
    dipstiktaco
    canada
    I did. He changed it due to it using coolant
