Valve/lifter Niose
Discussion in '4 Cylinder' started by XLR8NC6, Jun 11, 2014.
  1. Jun 11, 2014 at 12:19 PM
    XLR8NC6
    XLR8NC6 [OP] New Member
    Shalen
    San Jose CA
    Tacoma
    I had my Head resurfaced and valve job done along with Piston,rings and berings replaced.
    I had only driven 120 miles since when the heater core hose busted that dumped all coolant overheating the engine. Replaced all hoses,fan clutch and radiator .....figured get all done.
    Now I hear ticking noise from the top end which definitely sounds like lifter or valve noise.
    My question is that is it possible the oveheating damaged the head? there is no head gasket leak.. Thanks in advance
  2. Jun 12, 2014 at 6:38 AM
    Fordless
    Fordless Well-Known Member
    Jack
    Central Alabama
    2015 Tundra DC SR5+
    One of your lifters may not be shimmed properly, causing too much clearance and ticking as a result. I would recommend having them all measured and reshimmed to spec.
