Valve Noise
Discussion in '1st Gen. Tacomas (1995-2004)' started by Raspberry, Mar 9, 2023.
  1. Mar 9, 2023 at 6:26 PM
    Raspberry
    Raspberry [OP] Well-Known Member
    Andrew
    1995 Tacoma 4x4
    Full restoration
    Hi all, I’ve got a 95 4x4 2.7l 5spd.
    Just got done doing a JDM swap (long story, my dad blew up the old motor). Put a JDM 2.7l in it, put it together, cranked it up and runs fine, except there is a moderately loud ticking. I know the Tacoma tick is a thing, but this ticking goes away above 2k rpms and when you let off the throttle, it goes away while decreasing rpms but after a second of idle it comes right back. A long screwdriver revealed that it is coming from cylinder 3/4 of the exhaust side, in the head.
    So I tore the valve cover off, checked valve clearance, and sure enough every exhaust valve was tight (intake was all fine).
    The exhaust specs are .01-.014 and they were all in the .008-.009 range, except cylinder 3 was .006 and .008. I pulled the exhaust cam off to remove the shims and when I got to cylinder 3, on the bucket with the .006 clearance, the bucket would not turn around freely, it would get stuck and be hard to turn as I was turning it to get to the slot to pop the shim out.
    I am wondering. Can I replace the valve keeper and/or retainer, get new shims, and go?
    Could there be more damage that I should worry about?
    I should also mention that the engine runs perfectly fine.
  2. Mar 9, 2023 at 7:01 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Are you sure the ticking wasnt coming from the injectors.....
    some of them can make a lot of noise.....
    a stethoscope would be the way to check those.
  3. Mar 9, 2023 at 7:10 PM
    Raspberry
    Andrew
    1995 Tacoma 4x4
    Full restoration
    It really didn’t sound like it was coming from that side of the engine.
    But either way cylinder 3 still has tight clearance and this issue…
  4. Mar 10, 2023 at 1:24 PM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    I'd say a cheap borescope purchase, and a look down the spark plug tubes into that cylinder wouldn't be a waste of time or money. But given the fact that it was otherwise running fine, if that borescope checks out, I would just replace the keeper and/or retainer, adjust clearance with new shims, and see what happens.
