Valve stem
Discussion in 'Wheels & Tires' started by the glen, Apr 9, 2017.
  1. Apr 9, 2017 at 2:09 PM
    the glen
    the glen [OP] Well-Known Member
    Glen
    penisula
    2012 TRD Off-Road 6SP manual spruce mica Taco
    Icon 2.5 remote res. Coilovers front, icon 2.5 rem res shocks rear, deavers 10 pack leafspring rear. Light racing ouca. Cmc, avid light bar, bamf sliders weld on, grillcraft mx grill, bamf light bracket with lightforce 170's. Uws toolbox, oem bed mat, weathertechs f/r, hella airhorns, trd antenna, talegate mod, Clifford alarm, budbuilt full skid plate set. All pro rear bumper. Superbumps bumpstops. Bulldog lighting reverse led lights in bumper. Trd short throw shifter. Cobra cb, firestick 4' ant. Icon LCA skids. Bamf rear dif skid. Hi lift x-treme mounted with relentless rail mounts in bed. Full size method/bfg in bed. Crown performance ss/Kevlar brake lines. Power tank mounted in bed. Rigid d2s mounted on relentless hood mounts. H3R quick release fire extinguisher mounted to driver's seat. Redline hood struts.
    Hey guys, so i was using a compressor to air up my tires earlier and when i pulled the air line of the compressor off my passenger side front tire, im not sure what i did, but air is coming out,kinda like if u held a knife or screwdriver to air down. I tried my arb rapid deflate kit to tighten up the pin inside (im not exactly sure what u call this) but it doesn't work. I guess maybe its broke. My question, can i buy this pin from a tire shop, and just put it in?
  2. Apr 10, 2017 at 3:45 AM
    bludweiaer
    bludweiaer Well-Known Member
    pa
    2017 Pro DBL Cab,,2020 F3L Spyder...Polaris 800..
    avs rain guards,,,tyger auto tubesteps... stealth SR8's.265/70/17,ridge grapplers..shiftsense pro...
    sounds like the core is damaged,, need tool to remove the core, and replace with new core , or a completely new valve stem
  3. Apr 10, 2017 at 4:37 AM
    Clearwater Bill
    Billy
    Largo Florida
    dribble some dish soap around the area and let the bubbles tell you where the leak actually is. You may have torn the base of the stem itself.
    The 'thingy' is called a Schroeder valve.
    Edit: Schrader valve. :D
  4. Apr 10, 2017 at 5:54 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Does it hold air or does it not.. Idk something about a cat lol
  5. Apr 10, 2017 at 5:56 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    the glen[OP] likes this.
  6. Apr 10, 2017 at 6:22 AM
    the glen
    Glen
    penisula
  7. Apr 10, 2017 at 6:26 AM
    riz_atx
    riz_atx #bigpermtaco #teamBP
    Sohail
    Spicewood Texas
    ‘16 4x4 DCLB GFC Locked, Geared, Tuned
    C4Fab/RCI/BAMF, ADS, 4.88, Lockers, OVTune
  8. Apr 10, 2017 at 6:27 AM
    Clearwater Bill
    Billy
    Largo Florida
    Any parts house should have them. If not separately, just buy a stem and move the valve from it to yours.
    I guess if you are a Prime customer and can afford the down time Amazon is fine, just offering an alternative
  9. Apr 10, 2017 at 6:28 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    Y
    Yes the valve cores are pretty much a standard to Cars/Trucks. Large trucks(semis) and bicycles may use a different style.
  10. Apr 10, 2017 at 6:30 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    Also grab these caps, with seals. They will help temporarily seal air if you have a damaged valve core, not a permanent fix.
    https://www.amazon.com/gp/product/B002P8EMGI/
