Valve Tap? Clicking.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jmettx, Jun 27, 2016.
  1. Jun 27, 2016 at 8:54 AM
    jmettx
    jmettx [OP] Active Member
    2005 TRD V6
    I've got what sounds like a valve tap (clicking) on my 2005 Tacoma V6.
    A friend suggested that I try to run some detergent/flush/treatment through the oil system.
    I'm not sure that would make a difference, but I'm willing to try.
    Any thoughts on it if is worth trying? If so, any product recommendations? Thanks.
  2. Jun 27, 2016 at 8:56 AM
    cory02taco
    cory02taco Well-Known Member
    Cory
    Maine
    2013 trd super sport
    If it's louder than the normal taco tap you may want to have your valve clearances checked. If something is out of spec all the cleaners in the world won't make it right.
  3. Jun 27, 2016 at 2:08 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Agree with the above, cleaners are not going to help any valve tapping.
    Are you pretty sure it is the valves and not something else making the tapping noise?
    How many miles on the 2005?
    You could try getting a grade thicker oil and see if that will quiet down the tapping.
  4. Jun 27, 2016 at 2:54 PM
    jmettx
    2005 TRD V6
  5. Jun 27, 2016 at 3:30 PM
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
    I'm no expert but it sounds like normal valve noise to me. Has it recently gotten louder? I researched this extensively in my motorcycle ("yamatick") and the general consensus was it is when you stop hearing that noise that you have to worry.
  6. Jun 27, 2016 at 5:20 PM
    Hot Tacoma Blown
    Hot Tacoma Blown Well-Known Member
    NewYork
    05 4×4 tacoma
    Super charged,urd u - conn computer 7th injector, headers, pipe bomb y pipe,high flow exhaust.etc....
    My 05 ticked since day 1 now boosted and more same sound by the engine A lot louder in the exhaust.I love marvels mystery oil for a day before oil change run 10/30 high mileage and a quart of Lucas oil stabilizer.I do every change .But if ticket changes Go see a knowledge Toyota mechanic..Or as usual turn the radio up to 11 why it is 1 better than 10!!
