Valvoline max life how long does it last
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Backt, Feb 9, 2018.
  1. Feb 9, 2018 at 2:38 PM
    Backt
    Backt [OP] Well-Known Member
    Oregon
    2012 Tacoma DCSB Off Road Pryrite Mica
    I flushed the Toyota WS transmission fluid out about a year and a half ago and driven about 40k miles since then. I called Valvoline and asked them how long it lasts and they said to go by the manufactures recommendation of 100k and they would stand by that.
    To me that seems a little long. To those that have made the switch how often do you do a pan drop or flush? I currently have 88k on a 2012 off-road.
  2. Feb 9, 2018 at 2:43 PM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    The manufacturer of the A750 (Aisin) says to change the fluid every 30,000 miles or 25,000 for severe duty.
    Here is a picture reguarding how long fluid can last, it mostly depends on heat. 469700A4-723C-4F47-8971-4334915D87D9.jpg
  3. Feb 9, 2018 at 2:43 PM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    I believe the change interval is now 60k on our tacomas. @gearcruncher is the resident transmission guru.
  4. Feb 9, 2018 at 2:44 PM
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
  5. Feb 9, 2018 at 2:45 PM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    I for one say it's hard to beat a person at their trade. When you have years of experience and education behind the decisions of the Engineers, Chemists and suppliers of a product - I usually do not second guess them without very good reasons (observed Contamination, Burned, etc.). But if it floats your boat - just change it now ....
  6. Feb 9, 2018 at 3:33 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    The general rule of thumb I've deduced from transmission shops is do a drain/refill every 30-40K, or a full flush every 80-90 K. And change the filter every 100K or so. This is for normal use. Severe duty service would shorten that 25-50%.
    Toyota says to inspect/adjust ATF every 30K, and to replace ATF every 60K if towing (aka severe service).
    I flush every 80K or so. I don't tow but do off-road in the dez. 80K is a good compromise for me.
  7. Feb 9, 2018 at 4:02 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    You are only 12000 miles from manufacturer recommendation. Just change it now, no worry, no problem just be happy. After this just follow manu rec or change it a little sooner if it makes you feel better.
  8. Feb 9, 2018 at 4:09 PM
    BWilley
    BWilley Well-Known Member
    Brian
    Seattle
    2005 Tacoma DCLB Prerunner Desert Sand
    Skid plate, TRD Exhaust
    Sooner = Better
    Later = ??
