Valvoline said Tacoma will only take Full Synthetic Oil ???
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ThatGreg, Jun 4, 2018.
  1. Jun 7, 2018 at 8:35 PM
    #101
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    I'm in the IAM Union, we got a $10 raise on our last contract, and thus bought the Tacoma. :anonymous:
  2. Jun 7, 2018 at 8:54 PM
    #102
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    You can get Mobil 1 cheaper with their rebate I've gotten 6 5 qt jugs in my garage currently all for about 13 dollars after tax and rebate
    CMD-KY, Vbpiper and shakerhood like this.
  3. Jun 7, 2018 at 9:59 PM
    #103
    Tcoma16
    Tcoma16 Galatians 2:20
    California
    2016 TRD Sport
    I change every 5k
  4. Jun 7, 2018 at 10:08 PM
    #104
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    I’m thought you can only get 0w-20 I’m full synthetic and they don’t make blends for that weight
  5. Jun 7, 2018 at 10:10 PM
    #105
    TACORIDER
    JAKE
    EAST TAWAKONI TEXAS
    I only change it on one of our vehicles since the others are lifetime free changes, your autozone won’t take the oil, they do here. If they are full I save it and use it for the next burn pile, gear oil burns really nice
  6. Jun 8, 2018 at 7:11 AM
    #106
    Tacowin1013
    Yeah between my wife who drives 150 miles a day and the taco, I'm changing the oil a few times a year so I always load up when the rebates come around and like @shakerhood I buy the filters in bulk. I don't trust dealers and quick lube shops for many reasons, always hear horror stories about stripped bolts, loose bolts, neglecting to change filters. And you would honestly never know
  7. Jun 10, 2018 at 2:52 PM
    #107
    Bryanccfshr
    Bryanccfshr Well-Known Member
    2018 Trd OR , 2018 TRD Pro 4Runner
    First of all it would enhance your stance if you understood the difference between tolerances and clearances. Tolerances are indeed narrower, while clearances are the same as they have been for over 50 years. Without understanding the difference this is lost upon you.
    This makes your statement a false tale.
  8. Jun 10, 2018 at 3:41 PM
    #108
    e6400ultra
    e6400ultra Well-Known Member
    NorCal
    2017 SR AC 4x4 MT 2.7L
    Just use full-conventional oil, OP. :thumbsup: :headbang: :fingerscrossed:
  9. Jun 10, 2018 at 3:47 PM
    #109
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    Here comes the GD&T talk... :stirthepot:
  10. Jun 10, 2018 at 3:54 PM
    #110
    Boatbldr
    Boatbldr Well-Known Member
    Florida
    2002 prerunner
    None
    "Why aren't you three inches tall?"
  11. Jun 10, 2018 at 5:24 PM
    #111
    Bryanccfshr
    I will just skip the discussion since bearings are built on intended speed and load and leave this conclusion
    • Higher oil viscosity produces greater minimum oil film thickness, more power loss due to friction and more uniform oil film pressure.
      In fact Lower viscosity is a trade for lower friction losses at the expense of hydrodynamic film thickness. They rely more in the boundary lubrication regimen.
      It is not the end of engines since many motorist have logged hundreds of thousands of miles on 0w20amd 5w20 without a second thought. At the same time, use profiles that would load the engine heavily, shock load the drivetrain or run at extended higher rpms could benefit from higher film thickness.
  12. Jun 11, 2018 at 9:34 AM
    #112
    A7thvengeancex
    A7thvengeancex Well-Known Member
    Hauppauge, NY
    17 TRD Sport DCSB
    Blue map lights
    I apologize sir I mis spoke clearances is the correct word
  13. Jun 11, 2018 at 9:42 AM
    #113
    Bryanccfshr
    I apologize for being short and blunt with you. I am normally quite open.
    Do you have any current specifications on crankshaft and journal bearing sizes?
  14. Jun 11, 2018 at 9:51 AM
    #114
    Greg617
    Greg617 Well-Known Member
    Greg
    New England
    2010 5-speed 4x4
    Dents and scratches... Fox 2.5 Factory
    This. A quick google search for 0W-20 conventional motor oil came up empty. Even Toyota brand 0W-20 is full synthetic.
  15. Jun 11, 2018 at 10:07 AM
    #115
    Bryanccfshr
