Valvoline synthetic trans fluid
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Welderman, Aug 13, 2016.
  1. Aug 13, 2016 at 5:37 PM
    Welderman
    Welderman [OP] Member
    Bill
    2017 Tacoma TRD off road gray
    Tonneau cover
    Has anyone done a full trans flush and fill on the valvoline synthetic trans fluid it is marked on the jug toyo ws compatible it's probably good stuff just curious if anyone tried it cost wise it's about $17.00 a gallon compared to toyo at almost $35.00 a gallon.
    I'm at 60 k change now gonna use the toyota juice this time and gonna go wit the valvoline next trip I've been a equipment mechanic for about 35 years and have never had any issue with valvoline products.....so I was thinkin on trying it
  2. Aug 14, 2016 at 4:08 AM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Do it. Works good, last long time. I even added lubegard platinum additive just because.
  3. Aug 14, 2016 at 8:14 AM
    jstrenn
    jstrenn Member
    2007 Tacoma 4X4 TRD Sport
    I had my transmission flushed with Valvoline Maxlife at 60K miles. Now I have 106K with no problems. I did a drain and fill on the transmission at 100K (approx 4 quarts). The old fluid looked perfect. Couldn't really tell the difference in color from the new fluid I put in. So in my opinion I think its great stuff!
  4. Aug 14, 2016 at 10:51 AM
    Welderman
    Bill
    Tonneau cover
    Thanks for the reply it's helpful ...
  5. Aug 17, 2016 at 2:24 PM
    PineTreeTaco
    PineTreeTaco Member
    Maine
    '13 Taco DCSB 4x4 SR5
    how are you doing your full flush? I will be doing mine this weekend and haven't really found full flush how to
  6. Aug 17, 2016 at 2:29 PM
    Welderman
    Bill
    Tonneau cover
    Mountain lion has a how to post just look for diy full flush for automatic transmission it's pretty good was gonna do mine this weekend.
  7. Aug 17, 2016 at 2:43 PM
    PineTreeTaco
    PineTreeTaco Member
    Maine
    Thanks bud! Cheers
  8. Aug 18, 2016 at 6:27 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
  9. Aug 20, 2016 at 12:21 PM
    Welderman
    Bill
    Tonneau cover
    Well did my full flush and refill on my auto transmission today per the instructions of mountian Lions post and it worked wonderfully, the first stuff that I drained from the pan was kinda dark not real nasty but dark, so I proceeded on with the cooler hose drain into the bucket after about quart number 6 it started to get that nice cherry red color to it so I did 9 quart drain and 3 to refill it back up left it warm to 125 degrees and checked level it ready for another 60 k now.
    At that time I will drop the pan and and do a filter also.....
    Happy motoring!
  10. Aug 21, 2016 at 4:51 PM
    PineTreeTaco
    PineTreeTaco Member
    Maine
    I dropped my pan, changed filter, cleaned magnets and pan and swapped all fluid using the garden sprayer method, (at 54k, I live in Maine and don't care to do this maintenance in February) all worked like a charm, and it shifts like a dream, I bought it at 20k and it has never shifted so well. I also changed my front and rear diff fluids, transfer case fluids(looked new) and did a coolant flush.
  11. Aug 21, 2016 at 4:53 PM
    PineTreeTaco
    PineTreeTaco Member
    Maine
    I also used the Valvoline Maxlife ATF btw
