Valvomax Drain plug
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 1948hummer, Jan 8, 2025.
  1. Jan 8, 2025 at 5:04 PM
    1948hummer
    1948hummer [OP] Member
    Hi, Has anyone installed the valvomax drain plug on their Tacoma that has the TRD pro skid plate? Is there plenty of room to operate the screw on hose connector? TIA...
    SGJarrod likes this.
  2. Jan 8, 2025 at 7:18 PM
    paulisinataco
    paulisinataco Well-Known Member
    Utah
    2022 sr access cab 4x4
    did mine a few weeks ago had no problems with a rci skid. I had to go between the skid and pan to connect hose. my hands wouldn't fit in the hole of the skid. I think yours is a square hole if memory serves me correct.
  3. Jan 8, 2025 at 10:27 PM
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    Works fine for me! Access is fine for a normal hand.
  4. Jan 8, 2025 at 10:46 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    They make those holes in the skid plates big enough for big hands to remove a drain bolt. The special valves are not wider than bolts, just taller.
  5. Jan 9, 2025 at 8:05 AM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    TnShooter likes this.
