Vapor leak detection pump leaking?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Chairmanmeow66, Mar 2, 2025.
  1. Mar 2, 2025 at 10:27 AM
    Chairmanmeow66
    Chairmanmeow66 [OP] Well-Known Member
    2020 Tacoma TRD off road
    Hello good people, was removing my spare tire winch mount this morning and realized that the gas tank was caked in dirt from what seemed to be a leak I cleaned it off and did a test drive now I have little splatters over the back of the fuel tank and some on leak detection pump. Anyone have some insight on this?
  2. Mar 2, 2025 at 10:57 AM
    Tacosauro
    Tacosauro Well-Known Member
    23 SR5 V6 & 24 TRD OR
    roof rack
    To be honest it is really hard to see. Do you have any other pics? is there any damage or holes on fuel tank?
    Chew and Chairmanmeow66[OP] like this.
  3. Mar 2, 2025 at 11:05 AM
    Chairmanmeow66
    Not that I can see maybe I will upload a better picture after some driving because I wiped the area clean before taking this picture
  4. Mar 2, 2025 at 11:09 AM
    Tacosauro
    roof rack
    You could just use UV flash light also, it should show. But yes its hard to see in picture.
    I personally haven't checked or seen anything yet, if I saw leak on ground i would check probably but none so far on mine. If its wet again it is probably leaking, maybe a stone chip or something
  5. Mar 2, 2025 at 3:06 PM
    Chairmanmeow66
    Here’s a few more pics I can’t really see any punctures anywhere
  6. Mar 2, 2025 at 3:26 PM
    Chairmanmeow66
    I’m actually thinking it’s coming from the pinion seal and is flinging diff fluid to the fuel tank.. but it also might not be.
    Tacosauro likes this.
  7. Mar 2, 2025 at 4:12 PM
    MindlessCorpse
    MindlessCorpse Well-Known Member
    2020 Tacoma TRD sport
    Doesn't look like fuel. Fuel would spread more...
    Chairmanmeow66[OP] likes this.
  8. Mar 2, 2025 at 4:16 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Drive more worry less it could have been from the road.
  9. Mar 2, 2025 at 4:29 PM
    Chairmanmeow66
    Yeah thinking it’s diff fluid from the pinion
  10. Mar 2, 2025 at 4:30 PM
    Chairmanmeow66
    Had a regear done 10k miles ago so maybe pinion seal didn’t get seated properly..
  11. Mar 2, 2025 at 4:33 PM
    Chairmanmeow66
    It also looks like it got flung onto the exhaust pipe
  12. Mar 2, 2025 at 6:08 PM
    Tacosauro
    roof rack
    Yes seems like its coming from somewhere else and just happens to be caught by fuel tank because its boxy size. I would avoid driving it until you find where its coming from, if its differential, you dont want to run low on it. Assuming its been spewing since yesterday or whenever you noticed it, maybe longer who knows
  13. Mar 2, 2025 at 6:27 PM
    Chairmanmeow66
    I just cleaned the diff breather just incase it was that but doesn’t seem to be actually leaking from the pinion just small bits of it flinging everywhere
  14. Mar 2, 2025 at 6:32 PM
    Tacosauro
    roof rack
    It has to be coming from somewhere, any smells on it? when you wipe it off, you cant see color of it probably with dirt?
    I want to say maybe one of the lines is leaking but I dont see any rust or damage to lines so no idea
  15. Mar 2, 2025 at 6:33 PM
    Chairmanmeow66
    I’m 80% sure it’s diff fluid coming from the pinion seal
  16. Mar 3, 2025 at 5:03 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Pinion seal leak will leave oil on the botom of the diff it is the lowest point and will show up even if it's parked.
  17. Mar 3, 2025 at 7:21 AM
    Chairmanmeow66
    Good point will have to check after work today Thanks for the insight
  18. Mar 3, 2025 at 8:28 AM
    MindlessCorpse
    Looks like it is also slinging onto the tire...?
  19. Mar 3, 2025 at 8:57 AM
    Chairmanmeow66
    Not sure I rotated it yesterday so it was up front
  20. Mar 4, 2025 at 1:04 PM
    Chairmanmeow66
    Yep can definitely see some seepage near the bottom here. thanks for pointing that out. Got in contact with the shop that regeared luckily they have a 2 year warranty gonna take it in this week thank you for y’all’s help
