Vapor pressure code
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rougarou680, May 17, 2023.
  1. May 17, 2023 at 1:12 PM
    Rougarou680
    Rougarou680 [OP] Swamp Lurker
    Lousyana
    2006 Tacoma 4.0 Prerunner, 2013 & 2014 Tacoma 4WD 4.0L
    Leveling kit, hydro dipped rims & skid plate on 2013, 6” pro comp lift & color matched rims on 2006.
    PO deleted the EGR & removed the vapor canister. I put in a resister for the egr code but don’t know how to get rid of the pressure code. Any ideas? I don’t remember what the code number is at this time.
  2. May 19, 2023 at 7:37 AM
    Rougarou680
    Lousyana
    Anybody?
  3. May 20, 2023 at 6:40 PM
    Rougarou680
    Lousyana
    Moderator delete this thread since it’s not getting any traction.
  4. May 20, 2023 at 7:28 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I don't think it would be possible to eliminate EVAP codes with the EVAP system removed because it's a very dynamic system, when the PCM runs various tests on the system it's looking for corresponding changes in vapor pressure. If it doesn't see the proper change it will set a code so just a static resistor isn't gona do it.
  5. May 21, 2023 at 12:17 PM
    Rougarou680
    Lousyana
    I appreciate the feedback. I was finally able to find more information on it & seems that is the consensus.
