Various Issues - 2016 Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ColtonsTacoma, Jul 21, 2017.
  1. Jul 21, 2017 at 12:47 PM
    ColtonsTacoma
    ColtonsTacoma [OP] Member
    Colton
    2016 Silver Tacoma TRD Sport 4x4
    Premium/Tech Package Upgrade
    I just wanted to make a post on a few things I have noticed on my 3rd gen Tacoma over the last year.
    2016 Tacoma - Silver, double cab, trd sport, 4x4, fully loaded with all options.
    Little bugs here and there. All seem to be fixable, just wanted to see if others have had any of these issues.
    1. The first is the front passenger side dash. It squeaks really bad by the pillar and speaker. I had to have the dealership place a foam insert to keep it tight and movement free. The sound was quite loud and VERY annoying. Recently, the other side now seems to be making plastic squeaks and rattles. I will wait a little bit and see what happens with that one.
    2. This is a cosmetic thing, but the glass or plastic panel covering the instrument cluster (speedometer, ect.) scratches so easily. When it got dusty the first time, I very gently padded it down with a microfiber cloth and it scratched it to death. Haha. It looks pretty bad when sun is shining on it. I have read others noticed this too. Can this be replaced by chance?
    3. Drivers seat. I have noticed that my seat is really breaking down on me. (Material wise) It just does not seem to be holding up very well at all. I wear dress pants most of the time getting in and out of the truck, but the stitching and cloth seems to really getting worn on. I expect wear and tear over time naturally, but only having the truck barely a year and having stitching and fabric wear already is surprising. Has anyone else noticed this at all? (I am a 23 year old male that wears dress attire for work and weighs 150lb by the way) I am pretty careful about not dragging in and out while entering and exiting, but who knows..
    4. Shifting - I know this is a known issue, but hopefully the hunting for gears issue gets better over time. Toyota seems to be actively working on this issue.
    So far, I think that's all I have. It's a great truck! I am very interested in the TRD PRO! One day, maybe! Let me know if you guys have any thoughts on the above!
    Please post anything you guys have noticed on your 3rd gens!
    #TeamToyota
    Thanks!!
  2. Jul 21, 2017 at 12:54 PM
    rewted
    rewted Well-Known Member
    2017 Black TRD Off-Road Double Cab Short Bed
    Warn Zeon 10-S, BFG KO2 265/75/16, Bakflip MX4, Split Dual Battery System, TRD Pro Grille, Tokonsha P3 Brake Controller, ScanGauge II
    Search is your friend on #4, get the TSB done.
    Curious to know which plant your Taco is built from? My observations were that the the ones from Baja are the shittiest and the Texas ones were marginally OK.
    My '16 had noticable transmission issues including the fluid being low.
    My '17 has been better but it needed the TSB too and now it's great.
  3. Jul 21, 2017 at 2:02 PM
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    Sub'd to see if anyone has a good replacement for the plastic/glass covering the speedometer. Mine too was scratched to hell when I used a high quality (chem bros) microfiber on it. I've used this thing all over my truck and no scratches so this thing must be cheap.... not a big deal but a replacement for cheap that would allow me to clean it without scratching it would be nice....
    On the seats... seat covers are your friend. but yeah, they should be coming apart on a relatively new vehicle regardless of your use. I went w/ Coverking Neoprene and they've worked out well.
  4. Jul 21, 2017 at 2:06 PM
    Pittrider
    Pittrider Pitty, those needing correction.
    Greg
    B.C.
    2016 MGM LTD LB
    Do you need to know, or care?
    One word...Katzkins.
    harrycary likes this.
  5. Jul 21, 2017 at 2:10 PM
    TejasTaco
    TejasTaco Grab a taco
    Katzkins are freaking expensive.
  6. Jul 21, 2017 at 2:11 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Yep things that all add up which is why folks like @aero90 just dumped their truck
  7. Jul 21, 2017 at 2:12 PM
    OffCamber00
    OffCamber00 Well-Known Member
    mat
    Charlotte
    2017 Super White SR5 DCSB
    Same here....dealer replaced the seat cover under warranty. Now I'm EXTRA careful and use my step going in AND out. I figure it this one breaks down i'm in for some Clazzios or the like.
  8. Jul 21, 2017 at 2:13 PM
    Pittrider
    Greg
    B.C.
    2016 MGM LTD LB
    Ya, but he can afford it. :thumbsup:
    Not quite, you need the leather!
  9. Jul 21, 2017 at 2:46 PM
    rsimi72
    rsimi72 Well-Known Member
    PNW
    2020 Tacoma SR5 Access Cab
    I think you have a couple options for the cluster lens. First, I used some plastic polish from Griot's and it helped quite a bit. I can still notice light scratches in the right light but much better. It's easiest to remove the silver or orange dash trim first. Second, I think I saw that a new lens was about a $20-$30 part to replace. I'm not sure yet how simple it is to snap on or off because I haven't tried yet. If it's simple that would be a good option. You might risk dust getting in there if you pull the lens I guess. Let us know if you learn anything about replacing the cluster lens.
  10. Jul 21, 2017 at 2:57 PM
    stevebaz
    stevebaz Well-Known Member
    2016 access cab, TRD offroad 4x4, Quicksand
    For the seat wear issue I went to reach for the drivers side grab handle so I can ease myself in and it wasn't there. Who would have thunk that such a little problem would caused such seat wear.
    GPsevinSixx and shakerhood like this.
  11. Jul 21, 2017 at 3:33 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I am hoping they add the driver side grab handle back on the 2018 so I can add 1 to mine.
    tcjacado likes this.
  12. Jul 21, 2017 at 3:36 PM
    rsimi72
    PNW
    It looks like the hardware is there, under the driver's side A-pillar, to bolt the handle to. Unless I saw it wrong. Now we just need the pillar trim to incorporate the handle.
    tcjacado and shakerhood[QUOTED] like this.
  13. Jul 21, 2017 at 3:37 PM
    Flytmech
    Flytmech Well-Known Member
    Jase
    Geneva Alabama
    2016 Tacoma TRD OFFROAD 4x4
    All Pro Offroad bed rack Defender Basket OME/Dakars Total Chaos ucas C4fabrications LoPro Smittybilt 9.5 comp Uniden 520xl (tuned) CVT Mt. Shasta Black Oak 50 curve led
  14. Jul 21, 2017 at 3:40 PM
    shakerhood
    Southern Ohio
    1 of the holes is threaded and the other spot just needs a nut-sert
    tcjacado and rsimi72[QUOTED] like this.
  15. Jul 21, 2017 at 3:42 PM
    fake808sports
    fake808sports Well-Known Member
    2016 Tacoma TRD Sport AC
    after reading about how easily the instrument cluster scratches up with even the finest of microfiber cloths...
    i had a lint roller in my truck for the purpose of lint removal but now I use it to dab dust and dirt of the cluster. seems to work and not scratch that thing up.
    Oldman808 likes this.
  16. Jul 21, 2017 at 7:53 PM
    shakerhood
    Southern Ohio
    I use some sort of Swiffer Duster and surprisingly it has not scratched yet.
  17. Jul 21, 2017 at 8:05 PM
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    I don't remember seeing the screw bosses on the pillars to accommodate that in the future when I had my DR side pillar trim off. :(
    Just the cover for the single bolt behind the SRS cap.
    shakerhood[QUOTED] likes this.
  18. Jul 21, 2017 at 8:06 PM
    shakerhood
    Southern Ohio
    The 1 spot is still threaded and the other is not.
    GPsevinSixx[QUOTED] likes this.
  19. Jul 21, 2017 at 8:09 PM
    GPsevinSixx
    Ros Angerus
  20. Jul 21, 2017 at 8:21 PM
    69others
    69others Well-Known Member
    Did he get a Honda Ridgeline ?
