Vegas BS Thread!
Discussion in 'South West' started by MOT, Apr 29, 2010.
  1. Jan 15, 2019 at 5:59 AM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    I've never done it myself, but definitely something that you can do yourself if you're able to do basic repairs. This video explains it pretty well.
    https://www.youtube.com/watch?v=m9W31KGy6k0
    taco_lv[QUOTED] likes this.
  2. Jan 18, 2019 at 11:01 AM
    15DCGreyTaco
    15DCGreyTaco Well-Known Member
    Dave
    Vegas
    2016 DC TRD OR
    TRD Pro rims, Meso Customs Ultimate Turn Signal, SSO Slimline bumper, KC Highlight lightbar, 1/2' leveling kit
    Findlay toyota replaced mine under warranty. there is a service bulletin out for this so they will fix if you are still under warranty.
  3. Jan 18, 2019 at 11:11 AM
    15DCGreyTaco
    Dave
    Vegas
    2016 DC TRD OR
    Got a softtopper!
  4. Jan 18, 2019 at 11:22 AM
    Mtnflyer
    Mtnflyer I'm big in Japan
    Las Vegas
    Mine too. At Findlay.
  5. Jan 18, 2019 at 7:40 PM
    taco_lv
    taco_lv Member
    Las Vegas, NV
    2017 Tacoma TRD OR 4x4 DCSB
    OME 888 / Dakars, 5100s, 285/75R16, SCS, 4.88
    I ended up ordering the ECGS bushing, and I’m going to do the install myself. Thanks for the response.
  6. Jan 19, 2019 at 9:03 PM
    PcBuilder14
    Brent
    Nor Cal
    Did a ~70 mile loop South of Las Vegas today.
    Found some wild horses as well. Was really tempted to get closer.
    I think I need some more travel. Rear shocks are my limit straps...
    Found a hang glider's ramp. Takes a special kind of crazy to willing run off a cliff.
  7. Jan 20, 2019 at 8:45 AM
    15DCGreyTaco
    Dave
    Vegas
    2016 DC TRD OR
    Looks like an awesome trip! Where were you? What kind of CB setup do you have? I'm trying to get mine up and running but I cant get it tuned. SWR keeps showing 3+.
    970btu likes this.
  8. Jan 20, 2019 at 11:30 AM
    PcBuilder14
    Brent
    Nor Cal
    This was going around Potosi Mountain down to Good Springs and then back up to Vegas via Cottonwood. Below is a link to the general route I took.
    https://www.gaiagps.com/datasummary...map&openPrint=false&layer=SatelliteWithLabels
    If you need help getting tuned I can help out, just let me know. It's usually a grounding issue. Mine went from an SWR of 4:1 down to 1:1 across nearly all channels once I got a good ground. Below is a good article to read for grounding issues.
    https://www.rightchannelradios.com/blogs/troubleshooting-guides/18428219-testing-for-a-ground
    My CB is a Cobra C75WXST with a 5' Firestik II on a heavy duty spring with a folding attachment all on a Cali Raised mount.
    Ran the small connector box that the antenna cable, mic, and power wires connect to under the driver seat.
    Then ran the mic between the seat and center console, and when I don't need the mic it goes into the center console via the cable indentation.
    ninjastar808, DurtGrrl and 970btu like this.
  9. Jan 20, 2019 at 12:01 PM
    15DCGreyTaco
    Dave
    Vegas
    2016 DC TRD OR
    Thats awesome. I would love to get an assist on the grounding. I'm almost positive thats what it is. Is your mount powder coated? Mine is so I'm wondering if I have to sand it down, its a Rago Fab mount by the way.
  10. Jan 20, 2019 at 12:13 PM
    PcBuilder14
    Brent
    Nor Cal
    Mine was, but I removed the powdercoating around the hole for the underside of the antenna stud to ground to. You can either do that or run a wire from the underside of the stud to the frame to create a ground so it doesn't rust.
    Depending on your stud type, below is a good picture explaining how the lower half of the stud has to be able to ground to the mount which in turns grounds to the body of the truck. If the antenna can't ground itself then you'll get high SWR.
    970btu likes this.
  11. Jan 20, 2019 at 12:25 PM
    15DCGreyTaco
    Dave
    Vegas
    2016 DC TRD OR
    Okay, i have the firering to the K4. I'll probably remove the powdercoating around the hole. I'll try that today and see how it goes. Thanks for the help!
  12. Jan 20, 2019 at 5:28 PM
    15DCGreyTaco
    Dave
    Vegas
    2016 DC TRD OR
    Success! went from 4+ to 1:1 on channel 1! It also helped when I actually tightened the post to mount.:frusty:
  13. Jan 21, 2019 at 6:26 PM
    PcBuilder14
    Brent
    Nor Cal
    Glad it worked for you! :thumbsup:
    I recommend checking it again after the next time you off road, just to make sure any vibrations don't cause it to lose it's ground. Had it happen to me on my 1st gen.
  14. Jan 24, 2019 at 12:12 PM
    evoix4me
    evoix4me Well-Known Member
    Just got a 19 OR looking to get on some trails with some of you guys soon
    scaramouche likes this.
  15. Jan 24, 2019 at 4:28 PM
    ptrick
    ptrick Well-Known Member
    Patrick
    Las Vegas
    07 Prerunner SR5
    Spotted @ Jones and 215 :bowdown:
    ninjastar808 and 15DCGreyTaco like this.
  16. Jan 24, 2019 at 7:49 PM
    CharlieThree
    CharlieThree Active Member
    Vance
    Las Vegas, NV
    2006 White 2.7L Prerunner SR5 5-Speed Manual
    LCE Headers LCE Short Shifter aFe Magnum FORCE Stage-2 Si Cold Air Intake aFe Catalytic Converter Magnaflow Exhaust Secondary Air-Filter Mod Resonator Delete Mod Lockable bed storage boxes Mod LED Interior Lights LED Brake and Reverse Lights ProComp (Ugh) 3" Lift Black FJ TRD Trail Team Wheels ABS Black Mesh Front Hood Grill Blacked out emblems Full window tint Tow Package Toolbox
    Hey everyone, we just moved out here. Looking to tag along on a few meets. Any ideas on the next one? Also, any good spots to trail out to and camp/hunt?
  17. Jan 25, 2019 at 5:45 AM
    PcBuilder14
    Brent
    Nor Cal
    Unfortunately stuff isn't posted on here a lot. There's Facebook groups that I follow that usually have a meet or trip planned.
  18. Jan 26, 2019 at 9:17 PM
    CharlieThree
    Vance
    Las Vegas, NV
    Thank you for this I'll follow these too.
  19. Jan 27, 2019 at 12:39 AM
    Norsemanvike
    Norsemanvike Well-Known Member
    Escondido, CA
    '18 Sport 4x4, DblCb, ShBd, BBP
    Hey Vegas folks... I'll be out from San Diego for the Baker to Vegas Relay race and was wondering if anyone wanted to take me with my stock '18 Sport 4x4 on a long trail somewhere. I've got stock suspension and 5" nerfs, so the trail would need to be kind enough for that. Date would Sunday, 24MAR2019.
  20. Jan 27, 2019 at 11:52 AM
    15DCGreyTaco
    Dave
    Vegas
    2016 DC TRD OR
    I'd be down to hit some trails! Not too many people post on here about trips, mostly on Facebook, but I don't have facebook, so I miss out.
