Vehicle Holster for Handgun?
Discussion in 'Guns & Hunting' started by NraFan, Oct 9, 2009.
  1. Oct 9, 2009 at 2:22 PM
    NraFan
    NraFan [OP] Join the NRA! Protect your freedom!
    JT
    SoCal
    2011 Sienna LE, rockin the mini van!
    Power sliding doors baby! WooHoo!
    Ive seen a couple posts on the site about a holster in the center console. Just wondering what anyone here has done to mount/carry a handgun holster in their vehicle. I have a CCW permit for out of state travel, so Im looking for a solution. I have a few ideas but was hoping your input would help. Any ideas or pics would be great. Thanks guys!
  2. Oct 13, 2009 at 1:13 PM
    NraFan
    JT
    SoCal
    No one has anything? 50 views and not a single reply? C'mon! :notsure:
  3. Oct 13, 2009 at 1:15 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    DubfromGA likes this.
  4. Oct 13, 2009 at 1:25 PM
    NraFan
    JT
    SoCal
    Thanks. Looks great!
  5. Oct 13, 2009 at 1:26 PM
    Incognito
    VA
  6. Oct 13, 2009 at 4:07 PM
    djs05tacoma
    djs05tacoma Well-Known Member
    Martinez, CA
    05 Double Cab TRD offroad 4x4
    3" OME Lift, 285's
    I don't really have an official "mount" but every pistol I've got seems to fit pretty well in the door of my truck. Might get a few looks at the gas station when the door flys open but, in all honesty I haven't my pistol budge a bit, and I was doing quite a bit of driving/wheelin/road huntin this past week.
  7. Oct 13, 2009 at 4:29 PM
    ashjwilliams
    ashjwilliams Well-Known Member
    I too suggest starting with a BlackHawk Serpa, although I also suggest investing in a Serpa quick disconnect kit.
    I intend to fasten one of the female connectors to the inside of my center console which will locate the firearm in a good draw positioning (once the center console lid is popped open). I'll post pics when I finish the job. I have the equipment but haven't completed yet. I'd like to locate it such that an HK P30 and XD Tactical 45 would fit (in the console with the lid closed) but the XD is at my father's house (in a more secure safe). The other female connector is currently in a maxpedition bag.
  8. Oct 13, 2009 at 4:32 PM
    Packman73
    Packman73 ^^^^ 3%er ^^^^
    The free state of Arizona
    2007 TRD Off Road
    Bilstein 5100's (front set @ .85"), OME 885's, chris4x4 anti-Taco-lean spacer on driver's side, Total Chaos UCAs, Rear Leaf Spring TSB, Toytec AALs, Black FJ TT Wheels, BFG 285/75R 16 AT Tires, TRD Exhaust, Viper Alarm, Fog Light Mod, De-badged, Blue LED Dome Light, EZ Clamped Tailgate, Wet Okoles, Satoshi Grill, 5% Tint, Engine Tick Fix, Black Rear Bumper, Black Center Valence, Exhaust Cut At Axle, Thanks for all the help chris4x4!
    I used to have a Kingston car/truck seat holster by Desanti. It worked pretty well but I chosse not to install it in my Tacoma. I just carry on my person.
  9. Oct 13, 2009 at 10:45 PM
    Masada
    Masada Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    when I carry, I carry on my person or leave it in the console next to me. I don't like the seat holsters...
    Just my .02
  10. Oct 14, 2009 at 10:53 AM
    NraFan
    JT
    SoCal
    Thanks for all the info guys. I like to keep my firearms concealed, so keeping it in the door doesnt work for me. I think I might try the blackhawk quick disconnect. Ill keep you updated on what I do. Thanks again for all the info.
  11. Oct 19, 2009 at 5:10 PM
    Abe Froman
    Abe Froman The Sausage King of Chicago
    Fayetteville, NC
    2023 SR DCSB 4x4, White
    Sup yall. Been lurking and learning for a long time, but never felt I had anything to contribute until now. I tried my hand at molding kydex and made a holster for my center console. It's flat on one side so as to be attached to the inside panel of the console. It holds a Sig Sauer SP2022 and an insight M6X weapon light. I'm a short dude, so with my seat so far forward, it's tough to draw the weapon straight back along it's bore axis. So I designed the holster to release the gun from the top and it works quite well. I didn't plan for it, but the holster actually turns on the light when the gun is drawn - pretty sweet bonus. Check it:
    http://www.youtube.com/watch?v=rDoPcoqsdXs
    Anyway, if you've ever thought about doing something like this, I say go for it. It was much easier than I had imagined. Kydex is very forgiving stuff. You can work it and rework it and if you fubar it, just give it enough heat and it will go back almost all the way to it's original (flat) position. I didn't cast a plug of the gun, I actually molded the kydex right to the Sig itself. No surface damage of any kind. I first popped it into the oven to get it just soft enough to wrap around the gun, then I hit the parts I wanted molded tightly with a heat gun. After that I quickly clamped it down under a couple layers of some heavy foam-rubber floormat scraps and plywood I had laying around. Let cool, trim, add 3M tape and you're done. 2 other points of detail: I made a small insert for the trigger guard so the kydex wouldn't sink in and touch the trigger. Also, after I trimmed it, I reheated just the spine (bottom) of the holster and bent it slightly more closed so it would give a little tighter grip. If you have all the tools and supplies, you can make one for 3 bucks. The 6x9 sheets on ebay are just big enough for this set up and you can get 8 shipped for $22.50.
  12. Oct 19, 2009 at 5:38 PM
    ross45acp
    ross45acp New Member
    Larry
    Oklahoma
    08 tacoma 4x4
    Thats the best holster mount I have seen. I just stick my 45 under my butt. Do you think a AR will mount like that?
  13. Oct 19, 2009 at 5:41 PM
    Abe Froman
    Fayetteville, NC
    an AR in the center console? Oh, absolutely. But you might need to collapse the stock a notch or 2.
  14. Oct 19, 2009 at 5:54 PM
    glennv
    glennv Well-Known Member
    Just curious but do you guys live in states where you can't carry into certain places? In Rhode Island there are no restrictions on where you can carry other than the post office and any other federal buildings. I find myself stuffing the gun under the seat when I need to mail a package. Makes me wish the glove box locked.
  15. Oct 19, 2009 at 6:03 PM
    moto932
    moto932 What's the matter, Colonel Sandurz? CHICKEN?
    Eric
    Dayton, Ohio
    04 TRD Off Road
    Basically stock. OME 882s, HD Dakars and nitrochrgers, TG front bumper, custom rear bumper, 4Xinnovations sliders, RAT skids, Softopper, 255/85/16 ST MAXX's on 16" steelies, 1" B.O.R.A. wheel spacers Scangaugae II, deck plate mod, grey wire mod,ECGS bushing, diff breather relocation, alarm mod, defrost w/o compressor mod, de-badged, sockmonkey beside decals.
    im in a 1st gen and have been looking for a lock box for under my seat but there isnt shit for room down there so im having a hard time finding one. i dont want to just leave it in the center console (top or bottom compartment.)
  16. Oct 20, 2009 at 4:36 AM
    Front sight
    Front sight Well-Known Member
    SW Florida
    06 Prerunner TRD Sport
    Full OME 3"lift, LR UCA's,Destination 285/70/17's, 1.25 spidertrax, K&N drop in, 2nd filter removed, Weathertech liners, Toyota bed mat, reverse lights,Wet Oklee's, bedlights and other small stuff.
    Check your state statues before doing this. In Fl gun must be in a secure container or in snap holster- both out of sight. F.S. 790
    I'm ALL for the good guy's arming them selves. Just do it by the book in case you have to defend your self you won't get hemmed up.
  17. Oct 20, 2009 at 4:47 AM
    40204ever
    40204ever Well-Known Member
    Caldwell, TX
    4x4 taco racing development
    I like the seat pocket behind the passenger seat. The pistol is concealed and very handy. It is like it was made for it or a lb of beef jerky. If I'm on the road alone I scoot the passenger seat forward a little for better access.
  18. Oct 20, 2009 at 6:21 AM
    tacoeater
    tacoeater Well-Known Member
    Johnny
    Missouri
    07 TRD
    Weather Tech floor mats
    I carry my .380 ruger lcp in my center console at all times. When I go to the city (St. Louis) I usually carry my Kimber Covert .45.
  19. Oct 20, 2009 at 6:57 AM
    NraFan
    JT
    SoCal
    Hey ABE,
    I cant see the video here at work, but by chance I was looking on youtube last night and saw a tacoma holster that sounds like yours. I almost sent you a message last night to tell you to join us on here. Great job. Holster looks sweet. I look forward to seeing what else you have to offer. Welcome!
  20. Oct 20, 2009 at 8:55 PM
    kd8awe
    kd8awe Well-Known Member
    Rocky
    Ohio
    4x4 TRD Off Road
    Fog mod, 3" lift, ShoMe stobes, MicroLight LED Strobes, HiLift Jack, RCI 2950, Yaesu 8900r, 20% Tint, ScanGauge II, Weathertech Side Window Deflectors, *** New Mod's (parts on the way) *** U-Bolt flip kit. Tom Woods 1 Piece Double Cardan Drive Shaft. 3* Axel Shims
    In ohio the gun needs to be on you consealed or in a closed container in plain sight. If you are stopped you need to declair that you have a CCW and that you have a gun... If you touch it you are commiting a felony. You can NOT touch it. You must wait for instructions from the officer. Center console is considered a closed container in plain sight. That is where I keep my Glock 17 while driving. I keep my license and ccw in a id wallet that has 2 clear windows in the pocket on the sunvisor. That way both hands are in view of the officer.
    http://www.pickupspecialties.com/Consoles/Console_Vault/truck_and_suv_auto_console_vault.htm
