Vehicle not starting
Discussion in '2nd Gen. Tacomas (2005-2015)' started by M1ldlyAdequate, Dec 20, 2022.
  1. Dec 20, 2022 at 8:05 AM
    M1ldlyAdequate
    M1ldlyAdequate [OP] Member
    Karsten
    2011 Tacoma TRD Sport V6 4WD LB
    Over the hood pod lights and hard tri-fold tonneau cover
    Hey, guys.
    So I've been running into this issue where at least every other day when I go to start my truck everything powers on, like normal when I first insert the key and turn to the "on" position, but as soon as I turn the key to start the engine I hear a single click and loose ALL electrical power. So I hook it up to my jump starter and the electrical power comes back but the trip meter, clock, and radio presets all reset to factory settings. Then with the jump starter hooked up, I'll turn the key to start the engine and it'll start but die after a few seconds so I'll turn it again and it'll start just fine the second time. This has been happening consistently for the past month. I tried cleaning the battery terminals and that seemed to fix it for about a week, but then it started happening again and the battery terminals don't look like they've corroded already. Any ideas of what is causing the issue? Thanks.
  2. Dec 20, 2022 at 8:09 AM
    Clearwater Bill
    Billy
    Largo Florida
    Miles on the truck? Do you have a janitorial size wad of keys or stuff on your key ring?
    Is your main key worn down way more than the spare key? Have you tried using the spare key?
    Do you have a DVM to do a simple battery test yourself, or take it to a parts house to be load tested?
    steelcity2 likes this.
  3. Dec 20, 2022 at 8:24 AM
    steelcity2
    steelcity2 Well-Known Member
    Pittsburgh Pa
    2013 MGM DCSB TRD sport
    Bilsteins 5100's all 4 corners 1 inch rear spacer
    2WD and Geeves77 like this.
  4. Dec 20, 2022 at 8:28 AM
    Tacoma Mike
    Southern Maine
    Sounds like you have a crap battery connection.
    Raylo, Dm93, TnShooter and 1 other person like this.
  5. Dec 20, 2022 at 8:31 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The fact that you loose factory presets on the radio tells me you have main power failure from the battery.
    The next time this happens, hit the brake pedal and see if the brake lights come on. This sounds like a bad main feed wire. Hot or ground.
    Grab the big wires coming off the battery and rig and shake them.
    wilcam47 likes this.
  6. Dec 20, 2022 at 8:33 AM
    Tacoma Mike
    Southern Maine
    just because it looks good doesn’t mean it is.
    It could be a bad battery terminal , internal short etc, but you are losing all your voltage.
    That’s why your losing clock, radio etc.
    That’s also why your truck stalls on first start.
    4x4spiegel, Raylo, SR-71A and 2 others like this.
  7. Dec 20, 2022 at 8:49 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Check your connections at starter also
  8. Dec 20, 2022 at 8:53 AM
    M1ldlyAdequate
    Karsten
    The truck has 156k miles on it. I got it at 143k. I do have a lot of stuff on my Keychain but 90% of the time I detach the car key from the rest of it before I put it in the ignition. I have not tried using the spare yet, so I'll give that a try. There is some wear on the main key, but it doesn't look majorly worn compared to the spare.
  9. Dec 20, 2022 at 8:58 AM
    bs63366
    bs63366 Well-Known Member
    San Angelo
    2014 Tacoma TRD Off Road DCSB
    ARE Z-series shell, ImMrYo mirror lift, always on fog-lights.
    I would start with load testing battery especially since you are able to start with a jump box. That being said it does sound like there is potentially more going on with the wiring with losing all power and causing the factory resets, but I would start with the battery test and then work the main wiring from there.
    Geeves77 likes this.
  10. Dec 20, 2022 at 9:03 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Bad battery, loose battery connections, corrosion on battery connections.
    Clean and tighten first. If that doesn’t do it, get a new battery.
    YotaProject likes this.
  11. Dec 20, 2022 at 9:31 AM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Yup what he said!!!!
    Keep it simple at first
  12. Dec 20, 2022 at 10:09 AM
    M1ldlyAdequate
    Karsten
    Update:
    So I went to start my truck and surprise surprise it did the whole losing power thing and didn't start, but I waited about a minute and I noticed that the "door open" dash light turned back on (indicating the vehicle had power again) so I put in the spare key and it started no problem. Don't know if this changes the diagnosis or not. I do still plan on stopping buy the auto parts store later today to get the battery tested so I can hopefully officially rule out or narrow it down to the battery.
  13. Dec 20, 2022 at 10:44 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    That sounds like a bad cell in the battery to me. Dies and then after sitting a bit the charge comes back up slightly.
    SR-71A and TnShooter like this.
  14. Dec 20, 2022 at 11:13 AM
    Taco y mas
    Taco y mas Well-Known Member
    SoCal
    Tacoma TRD Sport
    None
    Battery cable connect at both ends. Check the other ends.
  15. Dec 20, 2022 at 11:21 AM
    Hunter gatherer
    Hunter gatherer Well-Known Member
    Andy
    Lillooet B.C.
    13DC4X4BaseModel
    Others have said it , it has to be a wiring connection. If it was a battery you would have at least something when you try to start,it would not be completely dead. When it happens again,turn your lights on and wiggle your battery connections hopefully they come on and it's easy to track down and fix. Did you notice any corrosion on your electrical connectors?
  16. Dec 20, 2022 at 3:10 PM
    M1ldlyAdequate
    Karsten
    I cleaned the clamps and terminals two weeks ago and there doesn't appear to be any corrosion on them. I haven't been able to take a look at any of the other connections, though, because the weather has been super gross and I have only been able to look at what is immediately under the hood. (Battery and fuse box) I'll try the headlight thing next time it happens and I'll let you know what I find.
  17. Dec 20, 2022 at 3:12 PM
    Raylo
    Raylo Well-Known Member
    MD, USA
    2023 Tundra SR5 OffRoad; (2009 Tacoma - sold)
    All stock, except for audio and convenience add-ons
    Had this exactly behavior with 2 different vehicles. Dirty battery terminals, even if they didn't look that bad. The first time I was in a company truck. The second time was in my Mustang. That time I knew exactly what to do.
    Edit: your post about cleaning the terminals popped up after I posted this.
  18. Dec 20, 2022 at 3:18 PM
    steelcity2
    Pittsburgh Pa
    U handy with a volt meter ? If so what's the battery voltage @
    Truck off
    Truck running
    Truck cranking to start.
    Jimmyh likes this.
