Vehicle Security Cameras
Discussion in 'General Tacoma Talk' started by FishWolf, Jul 8, 2023.
  1. Jul 8, 2023 at 9:59 AM
    FishWolf
    FishWolf [OP] Well-Known Member
    R Something
    2011 Toyota Tacoma
    Total Chaos Urethane Upper Control Arms FOX Factory Series 2.5 Remote Reservoir Front Coilover Shocks FOX Factory Series Remote Reservoir Rear Shocks 1-1/2” Rear Lift Block Kit Nitto EXO Grappler Tires (285/70R17) Method Fat Five Wheels – Custom color (17x7) Warrior Products Front Winch Bumper w/ D-Ring Mounts & Brush Guard Wurton 5” LED Light Bar (pair) – Installed in Front Bumper Warn Zeon Winch w/ Steel Cable & Fairlead (installed in Front Bumper) Warrior Products Rear Bumper w/ Integrated Hitch and D-Ring Mounts Wurton Scout Series LED Cubes (installed in Rear Bumper) Warrior Products Bolt-On Side Steps Warrior Products Platform Roof Rack Warrior Products Platform Air Dam Warrior Products Bed Rack Warrior Products Bed Support Tie Bar for Warrior Products Tacoma Bed Rack Bolt-On Spare Tire Mount (installed on Bed Rack) Warrior Products Black Diamond Plate Aluminum Tailgate Trim Warrior Products Black Diamond Plate Aluminum Sideplates Warrior Products Black Diamond Plate Aluminum Entry Guards sPod Switch Panel and Relay Kit Borla Cat Back Exhaust System Custom Vinyl Wrap
    Looking for ideas on good security cams to monitor outside of truck while away fishing etc, have had issues with vandalism in past, not sure how the wifi ones work either, I may not have access to wifi, does it just store in camera memory? Thanks for any suggestions
  2. Jul 8, 2023 at 10:10 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Common way to do it is a dual dashboard camera. Requires wiring a rear facing camera. Also requires a constant 12 v supply. This is so the camera can be available if it detects something while the vehicle is off.
