Vendor that sells tubing parts?
Discussion in 'Armor' started by rybern, Apr 20, 2020.
  1. Apr 20, 2020 at 7:43 PM
    rybern
    rybern [OP] Well-Known Member
    N Alabama
    2025 TRD OR & 2000 SR5
    I'm wanting to piece together my own full hoops on a plate bumper. Is there somewhere I can order these from and cut them to fit myself? I'm looking to do something similar to the Shrockworks hoops so I need 1.5" headlight pieces and a 1.75 or 2" center hoop.
  2. Apr 26, 2020 at 4:01 PM
    rybern
    N Alabama
    Anyone??? Bueller?
    I tried calling Shrockworks several times on Friday. I'll try again tomorrow. I've also sent Adam an Email at 4xI.
  3. Apr 26, 2020 at 4:10 PM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    I doubt it. The angle and bend radius are pretty specific to the bumper and style you are going for. If you knew the dimensions you wanted then maybe someone could bend the hoops you wanted.
  4. Apr 26, 2020 at 4:43 PM
    rybern
    N Alabama
    Thanks for the response. I suspect I should draw something up. Can you tell me what the standard radius is for 1.5" and 2" tubing is? Is there a standard radius for the different sizes?
  5. Apr 26, 2020 at 5:46 PM
    jowybyo
    Joe
    Baltimore, MD
    There’s not really a standard but it comes down to what bending dies are available. The following are likely options but you might need to adjust your design based on what the vendor has:
    *All listed options are for JD2 Model 3 and are the centerline radius.
    1-1/2” Round: 4.5”, 5.5”, 6.5”, 7.5”
    2” Round: 6.5”, 7.5”
    There are other options depending on the make of the bender being used. But generally the CLR for 1-1/2” tubing will be 4.5” or larger with options every 1/2”. And for 2” tubing it will be 6” or larger with options every 1/2”. Check with the vendor is my advice.
  6. Apr 26, 2020 at 7:13 PM
    rybern
    N Alabama
    Thanks Joe. That's very helpful. I want the smallest radius I can get so it looks like 4.5" and 6".
    Would you be interested in making these for me when I have a drawing?
