Vendors: do you have Icon RXT’s in stock?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hook78, Mar 3, 2022.
  1. Mar 29, 2022 at 3:10 PM
    #61
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    That's exactly my thoughts also... looking back at that link i shared in post #53 it appears he attached his clamp to the middle leaf bracket. I attached to the forward bracket... used a 3/4" hose clamp and left the bolts loose so the bracket/hose clamp can pivot when the suspension flexes. Also, changed out the mounting bolt to 1/4" longer and used a lock nut.
  2. Mar 31, 2022 at 11:48 AM
    #62
    Hook78
    Hook78 [OP] Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    When you install your leaf pack, don’t forget to grease the three bolts. I only remembered to do this on one side of the truck, and lo and behold the other side creaks. I will be reinstalling the bolts on the other side with grease this weekend.
