Vengeance Rear Bumper - Only 1 tag lamp works
Discussion in '2nd Gen. Tacomas (2005-2015)' started by d3javoo87, Jul 22, 2020.
  1. Jul 22, 2020 at 7:27 AM
    d3javoo87
    d3javoo87 [OP] Member
    Pennsylvania
    2015 Tacoma TRD
    I can't seem to figure out why only 1 of my license plate led lamp work after install. Both work prior. Passenger side works. Driver side doesn't along with the led strip that is also wired in conjunction. Resistors are installed on both side. Weird to me that only 1 lamp works. Any thoughts? Thanks.
    Hmm.. Thinking about removing the resistor since I have the led strip AND tag lamp...
  2. Jul 22, 2020 at 12:11 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Is the LED wired in correctly?
    I believe they only work one way?
  3. Jul 22, 2020 at 12:38 PM
    d3javoo87
    Pennsylvania
    2015 Tacoma TRD
    I triple checked. Even redone one of the connections because it thought it was a bad connection. I did research and gathered that the white/black stripe is ground and the green is the power wire. Connected the reds to the green and the black to the white/black.. Even switched the polarity, just in case. Still no go. I'm now wondering if the resistor is stopping it from working because I also have the led strip connected to that same tag light harness. Is that possible??
  4. Jul 22, 2020 at 1:33 PM
    Muddinfun
    Muddinfun Well-Known Member
    You shouldn't have a resistor wired into any of the running lights. Resistors are strictly for use with LED turn signals running off a non LED flasher.
  5. Jul 22, 2020 at 2:42 PM
    d3javoo87
    Pennsylvania
    2015 Tacoma TRD
    That sounds like the next step.. it's weird one lamp works with one tho.. I will remove them and see what happens! Thanks!
  6. Jul 22, 2020 at 3:04 PM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Get a voltmeter or test light to check for 12V at the wiring or swap sides to see if its a faulty led.
  7. Jul 22, 2020 at 4:27 PM
    d3javoo87
    Pennsylvania
    2015 Tacoma TRD
    it was just a bad ground.. ugh, thank you everyone for helping!
    Muddinfun likes this.
