Vent only blowing hot air
Discussion in '1st Gen. Tacomas (1995-2004)' started by EastTn, Apr 14, 2018.
  1. Apr 14, 2018 at 10:15 AM
    EastTn
    EastTn [OP] Member
    Aaron
    2004 Regular Cab Toyota
    My truck is only blowing warm/hot air. No matter if the selector is on cool or hot or even the A/C button on. Can anyone tell me what I should check to fix this problem. Summer is coming I need to get this fixed starting to burn up driving down the road.
  2. Apr 14, 2018 at 10:57 AM
    jammer
    jammer 2003 Toyota PreRunner 3.4L
    Ben
    Bentonville, AR
    2003 Lunar Mist Tacoma PreRunner 3.4l
    OME Coils/Bilstein 5100's front / 5125's rear 105 Amp Denso Alternator
    Hey Aaron, is the AC light blinking? I know that usually indicates there is an issue with the compressor.
    Also, when you turn the AC on, do you hear the ac clutch engage?
    Only other thing I can think of is maybe the blend air actuator is broken.
  3. Apr 14, 2018 at 11:01 AM
    Matt83
    Matt83 Well-Known Member
    Mine was the blend air actuator motor. It's located on passenger side
  4. Apr 14, 2018 at 11:05 AM
    EastTn
    EastTn [OP] Member
    Aaron
    The light on A/C does not blink...is the air actuator motor down near the floorboard? Has a wire harness plugging into it with like three screws holding it on?
  5. Apr 14, 2018 at 11:06 AM
    EastTn
    EastTn [OP] Member
    Aaron
    Also I think I hear the clutch for the ac kick on when I press the ac button
  6. Apr 14, 2018 at 11:14 AM
    20tacoma17
    20tacoma17 Well-Known Member
    2017 DCLB Sport AT
    Kings, 275/70/17, a few custom items, lots of Meso mods.
  7. Apr 14, 2018 at 11:16 AM
    EastTn
    EastTn [OP] Member
    Aaron
    Thanks!
  8. Apr 14, 2018 at 2:07 PM
    EastTn
    EastTn [OP] Member
    Aaron
    Actuator is not working any way to fix that? Also when I’m pushing the AC button nothing is happening does this motor have something to do with that as well?
  9. Apr 14, 2018 at 2:50 PM
    20tacoma17
    2017 DCLB Sport AT
    Is the AC clutch engaging? You should hear it click. Also, check all your fuses. Not familiar with early Tacoma's but trying to help
  10. Apr 14, 2018 at 3:03 PM
    EastTn
    EastTn [OP] Member
    Aaron
    When I push the button I don’t really hear anything but I thought it might be tied into the motor that’s not working? Not sure though?
  11. Apr 14, 2018 at 3:05 PM
    20tacoma17
    2017 DCLB Sport AT
    I don't believe it should since the actuator works with just heat even with AC off. Did you remove the actuator?
  12. Apr 14, 2018 at 3:31 PM
    EastTn
    EastTn [OP] Member
    Aaron
    I took the actuator off yes
  13. Apr 14, 2018 at 3:42 PM
    20tacoma17
    2017 DCLB Sport AT
    Does it do anything if you just plug in the electrical part and change the heat settings? If not then either a fuse, relay or it just went out.
  14. Apr 14, 2018 at 3:46 PM
    EastTn
    EastTn [OP] Member
    Aaron
    It don’t make a sound
  15. Apr 14, 2018 at 4:39 PM
    20tacoma17
    2017 DCLB Sport AT
    Have you checked to make sure control knob is actually turning switch? They get striped sometimes but sounds like fuse or bad motor.
  16. Apr 14, 2018 at 4:52 PM
    EastTn
    EastTn [OP] Member
    Aaron
    Yes the knob is fully turning
  17. Apr 18, 2018 at 5:17 PM
    EastTn
    EastTn [OP] Member
    Aaron
    Well I got the blend motor to working don’t ask me how I hooked it back up and it started working. Next issue I ordered a used control knob unit because one of the stems was broke off.....the first one I got worked fine except the ac light and fresh air light wasn’t lighting up. So the place I ordered it from sent me another one it’s also used. The refresh light comes on and works but the ac light does not come on nor does it get cold air.....I checked the fuse under the hood and it was good. What else can I do to look into the problem and fix it? I think the AC pump is located to the far left when looking under the hood and it is turning so what now?
  18. Apr 18, 2018 at 5:55 PM
    20tacoma17
    2017 DCLB Sport AT
    Possibly just bad connection. Glad you got it repaired.
  19. Apr 18, 2018 at 5:57 PM
    EastTn
    EastTn [OP] Member
    Aaron
    Thanks! I read to check an AC relay but in both fuse boxes I only see a fuse that says AC I don’t see a “relay” any idea where that’s located?
  20. Apr 18, 2018 at 6:08 PM
    20tacoma17
    2017 DCLB Sport AT
    Anything labeled Heater?
