Vent tube on actuator
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bluetoyota, Dec 4, 2021.
  1. Dec 4, 2021 at 1:53 PM
    Bluetoyota
    Bluetoyota [OP] New Member
    Doug
    Tacoma
    I just replaced my front 4 wheel drive actuator. In doing so I broke the plastic vent tube coming from the actuator. Will this be an issue or does it have to be connected to the hose.
  2. Dec 4, 2021 at 2:03 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    That should be connected, It will also be subject to the weather which is not good
  3. Dec 4, 2021 at 2:05 PM
    Bishop84
    Bishop84 Well-Known Member
    Easy fix, use a small red tube from a can of WD40 or whatever, cut to fit in both the actuator and the vacuum line, glue all together.
    6 gearT444E and Dm93 like this.
