Vent visors installation tips?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Logically Insane, Feb 3, 2010.
  1. Feb 3, 2010 at 11:51 AM
    Logically Insane
    Logically Insane [OP] Well-Known Member
    Wes
    TN --- USA
    2010 PreRunner Access Cab
    Kobalt toolbox mounted with J-Hooks, Locks on storage compartments in bed, Window Visors, Toolbox LED Lights, Underbody Lights, More to come.
    OK, I bought the vent visor things for the windows. Came with installation guide and all that. but when I went to put it in, apparently I bent it a little too much and it broke a big chunk out. Then when I took it out it broke the rest of the way, obviously with my temper I threw it as far as I could.
    Anyways, any of you guys with the visors have any tips for installation so that I can avoid this again?
    Thanks.
  2. Feb 3, 2010 at 11:54 AM
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Daniel
    Utah
    08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    My only tip would be, don't try to install them when it is super cold outside...
    Were they Weathertech's or a different brand?
  3. Feb 3, 2010 at 11:58 AM
    Logically Insane
    Wes
    TN --- USA
    Yeah I had a friend tell me to wait til it was about 60 degrees at least. But its pretty warm out. So I figured I'd try.. Ya'll know how it is.. Itching to throw it on. lol
    AVS I believe.
  4. Feb 3, 2010 at 11:58 AM
    AZBACKCOUNTRY
    AZBACKCOUNTRY Well-Known Member
    Doug
    AZ-between the hammer and the anvil
    11' AC TRD OFF-ROAD 4x4
    Pelfreybilt front aluminum bumper,AVID off road weld on sliders, RCI Offroad IFS & transmission Skid (steel),upper grillcraft, OEM color matched front grill color,OEM color matched-rear bumper, ARE MX camper shell, wet Okole realtree seat covers,pelfreybuilt hi lift mounts,Timcha shackle receiver,bulaculla trailer relocate harness,ICON 2.5 Coilovers, ICON tubular UCA's. Allpro expo leafs, SS extended brake lines.Bilstein 110 extended rear shocks.prinsu Cabrac.dwreck pod mounts OKLED 18w cubes.Baja Designs Squadron-R Sport, LED Wide Cornering, Ambers fog/driving 20" IGGY LED Single Row bar.tepui awning,rotopax 2 gallon, TREDs and mount , 100 watt renogy solar panel.morningstar PWM 30 charge controller. Pro comp wheels - BFG 265/75/16 AT's. Skygear bussman fuse relay smart box. ARB 12v plug hard wired for ARB fridge. Pelfreybilt gas tank skid. Smittybilt X2O 10K winch
    I had a bit of a challenge as well. I just installed the in trac vent visor, so I assume you tried this one also? But the instructions state to peel the tape near the mirror and a bit on the end towards the top of the window and fed those 2 ends in first. Creating a slight bow to the plastic. Then put some firm pressure to make sure it was ligned up and then remove the remaining tape covering so the adhesive can attach inside the track.
    One area that i needed to modify is up near the mirror it's a flat piece about 2" long , when I would open and close the window it would catch on this piece. So i used the dremel and removed about 3/8" of plastic and it put some 3m adhesive it this point and it opens and closes fine. For some reason this only happened on the drivers side? passenger side is fine.
    I would just take your time and what seems like a no-brainer can always be some sort of challenge when dealing with plastic as it always seems each piece is slightly different.
    They are nice in the rippin heat of AZ to leave the window cracked and also on a rainy day.
    Good luck.
    Azbackcountry
  5. Feb 3, 2010 at 12:02 PM
    Logically Insane
    Wes
    TN --- USA
    Yeah I was having the same problem when I did a dry fit. what I did was put it behind the rubber on the mirror. Seemed to be working fine.. until I tried to peel the tape off and put it in place..
