Ventilation mode control cable bent, won't move with dial
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Andy Savage, Apr 27, 2015.
  1. Apr 27, 2015 at 7:41 PM
    Andy Savage
    Andy Savage [OP] New Member
    Central Oregon
    2000 SR5 V6 4x4 extended cab
    While investigating why my ventilation system was stuck on defrost I found the mode control cable was disconnected from the dial arm. I manually changed the mode (from defrost to face, feet, etc.) with the mechanism the cable connects to by the gas pedal, which worked fine. The cable itself is bent where it meets the heater control assembly, and when reconnected to the dial arm it's too flimsy to push through the sleeve. Not sure if there's a way to help it move more easily without binding/bending, or if it's necessary to install a new cable. If that's the case where would I find one? Tried looking online without much luck for solutions and a replacement cable. Tried to upload a photo, hopefully it worked, not too computer savvy haha. Thanks in advance for any advice.
  2. Apr 28, 2015 at 6:26 PM
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    I'll move this to Tacoma discussion area for you where there should hopefully be some assistance for you.
