Vents in rear wall
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cruxx, Dec 22, 2019.
  1. Dec 22, 2019 at 5:33 PM
    TimC
    TimC Well-Known Member
    NY
    She’ll float a while longer now.
    Stocklocker likes this.
  2. Dec 22, 2019 at 5:46 PM
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    I think that's a bit of an exaggeration. I haven't had my truck long but, diff howl aside since I haven't experienced that yet, my vents (double cab) aren't bad at all.
    GreyBaldTaco likes this.
  3. Dec 22, 2019 at 6:13 PM
    cruxx
    cruxx [OP] Well-Known Member
    Huy
    2017 TRD Sport
    Well i got the back seats out and you literally have a Two 2” cracks to the outside of the truck. Thats like cracking your window 2”. The seats and plastic cubby probably muffle alot if the sound
  4. Dec 22, 2019 at 9:01 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    The vents got bigger in the 3G, compared to the 2G because more and larger air bags require more air to be evacuated from the cabin in a hurry. The air bags need to expand very fast to keep your face off the dashboard.
    This video also shows the front cab-mount, that guys like to chop, doing it’s job of keeping that passenger wheel from entering the cab and crushing the passenger’s legs.
    https://m.youtube.com/watch?v=1QfGMz-R7AQ
  5. Dec 23, 2019 at 5:02 AM
    RichVT
    RichVT Well-Known Member
    Rich
    Northern Vermont
    2016 Tacoma TRD Off Road 4X4 AC Grey
    My doors still close normally and my defroster still works fine after my modification. I try my best not to test the air bags but I suspect that a sudden change in pressure is going to blow air past the door seals. Just ask all of the people on this forum who have experienced the cross wind howl and water leaks how well sealed the doors are.
    I can tell you that in my access cab, turning the recirculate button on (which shuts off the fresh air intake and causes the rear vents to close) does sound like you just closed an open window. That's a good way to test if your rear vents are the source of noise you might be hearing.
    The rear vents by the way are a thin rubber flap that lifts open when there is air from the interior trying to escape and lay closed when there is no interior air pressure causing them to open.
    yub likes this.
  6. Dec 23, 2019 at 6:16 AM
    DiscoYaker
    DiscoYaker Well-Known Member
    SE USA and Alaska
    2015 Tacoma 4WD SR5 AC MT, 1995 Tacoma 2wd ext. cab auto
    Stock for now.. maybe
    So I work in Alaska (pretty much as far north and central you can get). We don't have Tacomas as work vehicles but i will say every year we always have several windows blow out while shutting doors, usually the back window. I imagine during winter the vents get Iced up and summer maybe filled from dusty roads? Just a guess but I figure it definitely has to do with the pressure and air not being able to flow properly. I like the foam c channel idea. For those that have them completely plugged on purpose maybe not a good idea. Might be ok for now or for awhile but eventually you might bust a window, especially if your vehicle seals well
    Edit.. maybe just an northern states problem. Just a bit of input from me. Enjoy your trucks
  7. Dec 23, 2019 at 6:41 AM
    Stocklocker
    17TRDORDCSBAT
    You know what happened to the last guy who plugged those vents.
  8. Dec 23, 2019 at 6:49 AM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    I’ve had the foam over mine for two years and other than my ears popping when I fart it’s been fine:eek::anonymous:. Haven’t tried the air bag thing, I think I’ll take my chances with that.:thumbsup:
    TimC and Stocklocker like this.
  9. Dec 23, 2019 at 8:14 AM
    TimC
    NY
    I thought about the countless victims with the window locks on.. fighting for oxygen.
    Hope is gone..
    Captqc[QUOTED] likes this.
  10. Dec 23, 2019 at 8:23 AM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    I want to see them do this with the TSS sensors on see if it does anything, unlike the guy that drove into cardboard boxes
    Stocklocker[QUOTED] likes this.
