Vents on the rear & bottom of center console
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MWCmike, Oct 17, 2008.
  1. Oct 17, 2008 at 6:16 PM
    MWCmike
    MWCmike [OP] Member
    Midwest City, OK
    08 Double Cab PreRunner
    None yet
    Can anyone tell me what the three vents are for on the back of the center console? (08 Double Cab V-6) No speakers or air comes out, and nothing in the book that I could see.....THX
  2. Oct 17, 2008 at 6:33 PM
    gavonder
    gavonder She's Kickass!
    Bethel, Ct
    08 TRD Sport Access Cab
    Sunroof, Leer Cap w/ Thule rack, Factory Running Boards, Fog Light Mod, Hood Struts, Scangauge, w/homemade mirror mount, AC/Defrost mod, Rear Spring TSB, TRD Center Caps
    I'm not positive, but I think that is where the inverter (for the bed outlet) is located and that is for air flow to cool it.
    GA
  3. Oct 17, 2008 at 7:03 PM
    pmo
    pmo Well-Known Member
    Nova Scotia Canada
    2007 Tacoma 4x4, DC, 6 Speed Manual.
    Heater vents???
  4. Oct 18, 2008 at 1:06 AM
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
    Are you talking about these? I have no idea what they are for.
  5. Oct 18, 2008 at 6:06 AM
    SteelCity
    SteelCity Wherever I May Roam
    Charleston, SC
    06 Radiant Rd DC LB PreRunner SR5 V6
    Optima Red/Stinger Terms, DT Headers, Empire O2 sim, Bluetooth, USASpec PA12TOY, Redline Struts, Extang Tonneu, OEM Bed Mat/front Skid/Roof Rack, Grillcraft Grille, Susp TSB, Toytec 1/2" front spacers, Raammat/Ensolite, Sony GTs, Curt Hitch, Tranny cooler, Wet Okoles, AFE Pro-Dry Drop in, Muth Sig Mirrors, Temp/Comp RVM, Silverstar HLs/Fogs, Royal Purple Diff/PS Fluid, Detroit Truetrac LSD, Hellwig rear sway bar, SG II, Filter Mag, 265/75/16 Nitto TGs
    Asthetics? Speed? :p
  6. Oct 18, 2008 at 6:40 AM
    hate2work
    hate2work Well-Known Member
    Washington State
    06 standard cab
    Those vents are for your water cooled muffler bearings. And that, of course, helps keep your blinker fluid the right temp. :D
    Seriously, I think they are just for aesthetics, nothing more.
  7. Oct 18, 2008 at 6:50 AM
    007Tacoma
    007Tacoma I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
    They are to allow air flow to the transmission well. Under heavy loads and mid range speeds, the heat from the engine and transmission can collect in this well. It passes through into the center console and shifter area. Without those vents, it is possible to damage some of the plastic components due to excessive heat buildup.
    Think, Arizona desert (no offense Chris) in late July pulling a 5,500lb trailer and a full bed with 4 people in the cab going up hill and then parking it at the top.
    Heat is Bad (most of the time).
  8. Oct 18, 2008 at 8:15 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Why would I be offended? I think your right on this one. Though the shifter and center console are sealed away from the tranny tunnel, being a high point under the truck, it is possible for heat to build in that area of the cab. Im going to research this one, as I see many trucks and SUV's with these vents in the rear of center consoles. :)
  9. Oct 18, 2008 at 8:22 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    OK. Being as there are electrical wires and lights in the console area, i.e. shifter, the vents are simply vents to allow air to flow thru the console preventing heat build up and shortening the life span of the electronics. :D
  10. Oct 18, 2008 at 8:35 AM
    mudslingin44
    mudslingin44 Well-Known Member
    west palm beach, fl
    07 tacoma double cab trd 4x4
    6 in pro comp coilover-35 in pro comp extreme mudders
    it's to keep the flux capasiter cool before going into the worm hole
  11. Oct 18, 2008 at 11:22 AM
    Okkine
    Okkine Well-Known Member
    Vancouver, BC
    2009 Magnetic Grey Access Cab - 2.7L I4 - 4x2
    Makes sense. In my old Neon on long trips I could really feel the heat coming from the opening for the hand break.
  12. Oct 21, 2008 at 7:47 AM
    rachunter
    rachunter Well-Known Member
    West Virginia
    08 TRD Off-Road
    XM Radio,Access Lorado Tonneau, Ventshades, Tinted Windows, Destination A/T's , Moto Metal wheels and lots of Liquid Glass
    Please tell me your kidding!!! :eek:
    gavonder hit the nail on the head
  13. Oct 21, 2008 at 8:13 AM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    x3.
  14. Oct 21, 2008 at 9:23 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    I bought some pre-wired blue LEDs and planed on putting a couple of them inside the vents to help light up the rear floorboard at night without having to use the overhead lights.
