Vermonters
Discussion in 'North East' started by gugman, Jun 23, 2010.
  1. Mar 30, 2017 at 12:17 PM
    #881
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    I perfer the Grade B over A anyday but it's harder to find!
    Jeffch likes this.
  2. Mar 30, 2017 at 2:19 PM
    #882
    gugman
    gugman [OP] analog
    bob
    Vermont
    I agree
  3. Mar 30, 2017 at 3:36 PM
    #883
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Just learned this over the weekend. We went to few sugar houses for the open houses they had. It's all grade A now.
    88nitro305 likes this.
  4. Mar 30, 2017 at 4:29 PM
    #884
    gugman
    gugman [OP] analog
    bob
    Vermont
    I'm still on the old grade system. I think it is much easier grade B vs. grade A dark with robust
  5. Mar 30, 2017 at 6:59 PM
    #885
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
  6. Mar 30, 2017 at 8:07 PM
    #886
    PintSize
    PintSize Crossthreaded & torqued down
    Texas
    2011 2.7L 5 spd RC 4x4
    First part of the season usually comes out grade A then later B. I regret my family had sold all our buckets and evaporator that we made.
  7. Mar 31, 2017 at 3:49 PM
    #887
    Jeffch
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Yea we did a commercial maker in Georgia then stopped to this family's sugar house in Essex jct.
    I grew up in the area and never knew it was there. The big guys had a huge RO set up. The family run one was way better, the granddaughter enjoyed it. And so did we. Just good people.
    Sunrise this am!
    COOL!
  8. Mar 31, 2017 at 3:53 PM
    #888
    Jeffch
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Yea I agree we are B people also.
    Guess I don't understand why it would be all A? Maybe our worst is still better than others?
    gugman[QUOTED][OP] likes this.
  9. Apr 4, 2017 at 9:21 AM
    #889
    GreyGoblin
    GreyGoblin Well-Known Member
    2014 Regular Cab 4x4 Tacoma in Magnetic Grey
    I'm posing a questions to all Vermonter's. This is my first truck, although I have driven a Silverado 1500 for work. Anyway, I'm sure you're all familiar with dirt roads and how they get after snow melt and rain. When I drive my truck over these consecutive bumps at around 20 mph the truck, no kidding, swerves wildly and loses control. I have to slow down to about 5 mph to drive across these very bumpy areas otherwise the loss of control is too great and I'll end up in the ditch. I know this is a problem for a few reasons. It just doesn't feel right. The silverado doesn't exhibit this behavior. This morning another Taco was coming up from behind me and I was going too slow, I had to let him pass. I watched as he trucked right along seemingly absorbing the road faults with ease and control.
    From what I can tell the truck is bone stock. The only thing that has been modified is the wheels. Currently on 265/65 R17. I checked to see if the sway bar was removed, it's still there. What could be causing this issue? Also at highway speeds, going up I89 to Burlington, the truck is constantly, albeit very slightly, swerving left and right. Almost like I'm driving in a crosswind. It's taking constant correction to maintain a straight course.
    Any ideas what to check? Has anybody experienced this, particularly if you have a regular cab? I'm wondering if the regular cab is so light, especially with an empty bed that it simply cannot maintain road contact and as the rear bounces into the air the rear end swings out, too far for front wheel correction to remedy.
    Thanks for any help.
  10. Apr 5, 2017 at 12:18 AM
    #890
    88nitro305
    88nitro305 Well-Known Member
    Tom
    Vermont
    2012 white DCSB TRD OR
    Is there a member on here that was in Colchester around 1:45 yesterday with a White TRD AC lift and black rims? Military person also?
  11. Apr 5, 2017 at 7:23 AM
    #891
    MadRiverTaco
    MadRiverTaco Join TW, they said. It's free, they said.
    Brenden
    Waterbury, VT
    2012 Black DCSB TRD OR "Caroline"
    King 2.5 Ext. w/ Compression Adjusters (Front & Rear), Dakars w/ D29XL, TC UCA's & LCA's, ARE CX, 17" SEMA Pro's, 265/70/17 Falken Wildpeaks, BORA spacers, Rigid Side shooter ditch lights, ATHF bedside reinforcements, OME carrier bearing drop bracket, extended rear brake lines, Northstar 27F battery, Yakima Jetsream crossbars, OEM roof rack, OEM skid plate, TRD Pro grill, URD TCAI, 5.7L Throttle Body, BensonX bedside tool mounts, fire extinguisher bedside mount, AMP research bed step, Redline Tuning hood struts, ECGS needle bearing mod, CV Boot slide mod, Differential breather mod, U-Bolt Flip Kit w/ Timbren Bumpstops, A-pillar RAM mount w/ cell phone holder, ProFX tow mirrors with turn signals and heat, "Raptor" lights, DEPO taillights, motorized Pop n' Lock
    For those of you who have lifts and got an alignment after install, where did you go? I'm trying to avoid the dealership and shops that don't have experience with aftermarket lifts and won't dial in the right specs. Ideally it would be a shop that's reasonably priced and somewhere between Montpelier and Colchester.
  12. Apr 5, 2017 at 4:31 PM
    #892
    Jeffch
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Not gonna be a lot of help here but I know I get axle wrap I guess on expansion joints on certain bridges. Having weight helps I guess to set the springs with a load, again not positive. I've read the shocks are going opposite directions to make it better but still the springs want to make s shapes. I run 265/75/16 and the wider tires for me seem to steer where you point it unless they find the rut and they like to stay in them.
  13. Apr 5, 2017 at 4:34 PM
    #893
    Jeffch
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Pretty sure I saw it today. Maybe it was you? Not sure if it was a ac or not.
    By CHS at like 5:15pm.
  14. Apr 5, 2017 at 4:39 PM
    #894
    GreyGoblin
    Thanks for the answer. Seems like no one has much to say on the matter. I learned today that if I put the truck in 4wd that the loss of control is significantly diminished. I like the look of the wider tires but not if the exchange is poor performance.
  15. Apr 5, 2017 at 4:40 PM
    #895
    Jeffch
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    I was pleased with Baileys in Essex. Old school kinda I'm sure they would do what you ask. Ours are toys compared to what normal do.
    MadRiverTaco[QUOTED] likes this.
  16. Apr 5, 2017 at 4:46 PM
    #896
    ARCOVT16
    ARCOVT16 Well-Known Member
    VT
    2016 DCLB SR5
    Icon ext Travel Coilovers, SPC UCA, SCS 16x8 Wheels, 285/75r16 G003, Toytec 3leaf AAL, Icon 2.0 Remote Reservior, Toytec Axle shims, Toytec Front Diff drop, Timbren U-Bolt flip kit, Clazzio Black Seat covers.
    https://the4x4center.com/
    Ask for Jason, he's great, and has a lifted Tacoma
    MadRiverTaco[QUOTED] and Jeffch like this.
  17. Apr 5, 2017 at 4:48 PM
    #897
    gugman
    gugman [OP] analog
    bob
    Vermont
    not sure if I get axel warp. I run the same tires 265/75/16 in the winter and 245/75/16 summer (Tires that came on the truck)
    I agree with Jeff baileys spring in Essex is very good
    Jeffch likes this.
  18. Apr 5, 2017 at 4:54 PM
    #898
    Jeffch
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    I have not been to 4x4 center so I got nothing there. But the guys at baileys were doing springs that I could not even carry. They asked if it was ok to use the impact on my lugs.
    My rear end kinda hops over stuff empty!
  19. Apr 5, 2017 at 4:58 PM
    #899
    ARCOVT16
    VT
    2016 DCLB SR5
    how many miles on your truck?
    stock tires on aftermarket wheels?
  20. Apr 5, 2017 at 5:02 PM
    #900
    Jeffch
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    @ARCOVT16 where are you from? Nice ride you like it ? Have seat get comfy,,
