Very annoying Clunk
Discussion in '1st Gen. Tacomas (1995-2004)' started by Indyteecee, Oct 29, 2019.
  1. Oct 29, 2019 at 12:22 AM
    Indyteecee
    Indyteecee [OP] bad at building Toyotas, good at breaking stuff
    Wyatt
    Utah
    04 Tacoma Double Cab TRD
    Sorry for posting so many noob threads here, but I have a new annoyance. I just installed new ome leaf springs, shackles and u-bolts and am now getting this really loud clunk when flexing the suspension. Obviously my first thought was that is has something to do with the stuff I just installed, but I check everything and it looks fine. The odd thing is, it sounds like it changes where it’s coming from, sometimes it sounds like its coming from the driveline, sometimes front suspension and sometimes rear, and I can feel it in my feet. I know it’s going to be a hard thing to chase down, but I’ve had a lot of my issues solved on this forum so why not try. Here is some video of the clunk. Sorry about the other rattling noises.
    https://youtu.be/6XckRi6jQqQ
    https://youtu.be/mWUkwAwZsb0
    GQ7227 likes this.
  2. Oct 29, 2019 at 12:30 AM
    1st4x4
    1st4x4 Well-Known Member
    sam
    Torrance
    98 tacoma 5 speed 4x4
    tundra front clip, tundra brakes, cab cage, camburg long travel, archive garage rear shock relocate
    Carrier bearing?
  3. Oct 29, 2019 at 7:20 PM
    chrispartida
    chrispartida BDPNTJB
    Los Angeles
    2003 Black TRD 4X4 with a shitty clear coat
    2003: Bad clear coat, OME HD kit w/Dakar leafs, ShmellFab sliders, Badland Bumpers rear bumper, Bestop Supertop & Yakima/Tyger roof rack. SOLD - 2002: TRD PreRunner with a DERP sticker, some desert stripes, couple of rock scrapes, E-locker, OME front & rear w/Dakar leafs, and CURT front/rear hitches.
    A very good place to look. Get under there and give it a shake.
    Does your truck have more than 2" of new lift? How immediately did it start up after installation?
    Indyteecee[OP] likes this.
  4. Oct 29, 2019 at 8:03 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Those 2 second videos weren't super helpful, lol. Also a lot of background noise, and we can't tell where it's coming from anyway.
    When *precisely* does it make the clunk? Is that consistent? Like only when the right rear flexes up under power, only when turning left and inside corner hits a bump... that sort of thing...
    Years ago, I had what I *thought* was a suspension clunk on acceleration from a stop. Changed almost everything, control arm bushings, ball joints, shocks, even switched drivelines with a friend. It turned out to be the tube of my K&N intake clunking on the heat shield, lol...
    Running Board Man likes this.
  5. Oct 29, 2019 at 9:25 PM
    Indyteecee
    Wyatt
    Utah
    Tried the best I could. Better than no videos at all. That’s the thing that’s so weird it’s not very constant. The best way for me to recreate it is to go over a good sized bump sideways, at any speed really. Sometimes it sounds like it’s coming from the front, sometimes the back. Very frustrating.
  6. Oct 29, 2019 at 9:27 PM
    Indyteecee
    Wyatt
    Utah
    The lift got about an inch and a half taller I’d say.
    Pretty immediately?
  7. Oct 30, 2019 at 12:43 AM
    spikenick
    spikenick Member
    Nick
    Glendale, AZ
    03 Tacoma 2WD 3.4L TRD SR5 Auto Impulse Red
  8. Oct 30, 2019 at 5:12 AM
    Booker
    Booker Active Member
    Tony
    Valrico, FL
    1999 Tacoma TRD
    I have the same thing happening to my truck. Installed the OME lift (2.5 inch) about 2 months ago, but the noise just started last week. I haven't started to investigate yet, but just like the OP I feel it in the floor. To me it sounds like something is in a bind and it's popping loose. It's happens randomly. I even got it to do it once by rocking the truck side to side in the driveway.
  9. Oct 30, 2019 at 8:33 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Could be the poly bushings that most people install with the dakars. I had to put a new bushing in my oem spring pack, so I went with poly. Stupid thing would pop and creak like crazy, put an oem rubber one in there and its silent.
    I dont know if a rubber oem bushing will fit in the dakars though.
    Booker and Indyteecee[OP] like this.
  10. Oct 30, 2019 at 11:21 AM
    Indyteecee
    Wyatt
    Utah
    Yep exactly. Sounds like a pop or a bind.
  11. Oct 30, 2019 at 3:07 PM
    Indyteecee
    Wyatt
    Utah
    I do not have the poly bushings, for that specific reason. Heard people say that their pretty noisy. I just went with the regular ones.
    Blue92[QUOTED] and cruiserguy like this.
  12. Oct 30, 2019 at 3:09 PM
    Indyteecee
    Wyatt
    Utah
    What exactly am I looking for with the carrier bearing? Am I looking for play when I shake it? Or listening for a noise? Sorry still kinda new to all of this.
  13. Oct 30, 2019 at 3:27 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Good choice! My next choice after I recheck torque on everything would be the slip yoke binding.
  14. Oct 31, 2019 at 5:08 PM
    homegrown_xt
    homegrown_xt Well-Known Member
    Sonoma County
    1996 Tacoma Xcab 4x4 V6 MTM
    Rancho Quick lift. Wheelers Off Road Progressive AAL with Rancho RS9000's, braided brake lines & clutch line. BFG 32x11.50 15 All Terrain Tires Deck Plate Mod. Flowmaster 60 series muffler and Marlin Crawler Short Throw Shifter.
    When you did the final torque on the rear suspension did you make sure that the truck was on the ground or suspension was loaded for ride height before it was torqued down? If not, that is probably where the bind is coming from.
  15. Oct 31, 2019 at 5:35 PM
    Indyteecee
    Wyatt
    Utah
    Yep, full weight of the truck on the ground.
  16. Oct 31, 2019 at 6:05 PM
    homegrown_xt
    Sonoma County
    How about the brackets that are riveted on the leaf springs to keep the leafs lined up, are any of those rubbing on those?
  17. Oct 31, 2019 at 6:56 PM
    Ace115
    Ace115 Well-Known Member
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    Grease all joints on your drive shaft. Just got rid of clunks and a weird whistle by putting new grease into every Zerk
  18. Oct 31, 2019 at 8:31 PM
    Indyteecee
    Wyatt
    Utah
    I’ve thought about that. I’m going to cover those in wd-40 to see if it stops it.
  19. Oct 31, 2019 at 8:32 PM
    Indyteecee
    Wyatt
    Utah
    Just did that. No luck :(
    Ace115[QUOTED] likes this.
  20. Oct 31, 2019 at 8:34 PM
    Ace115
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    There are 9 zerks, did you get them all?
