very bad problem..
Discussion in '1st Gen. Tacomas (1995-2004)' started by Nitronick, Apr 3, 2012.
  1. Apr 3, 2012 at 12:17 AM
    Nitronick
    Nitronick [OP] Well-Known Member
    Nick
    Oregon City, OR
    98 tacoma sr5 v6 3.4
    So the other morning i was on my way to work at 430 am and i was going around a corner and a man hole cover was sticking up at about a 30 degree angle, swerved and completely nailed it with my front right tire..soo i keep on going to work. noticed that when i go over 30 my truck starts to shake, over 40 it gets worse..and so on. so i thought it was maybe my tire was off balence, so i checked if any weights were gone..but they were all still there. so i rotated the tire to the rear to make sure it wasn't the tire. soo now i have noise whenever i brake or gas that sounds like something is loose, or is slipping forward and backwards.. any thoughts? i checked my ifs on the right side, and it seems all fine and tight.. kind of out of ideas now. anything would help:confused:
  2. Apr 3, 2012 at 1:59 AM
    Anthony250
    Anthony250 Ex Fabricator
    Anthony
    Rialto CA
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    Check the tire it hit for any bumps.
  3. Apr 3, 2012 at 2:09 AM
    the.sight.picture
    the.sight.picture Wishes he was in the woods.
    Nick
    Blue Ridge
    2018 QuickSand
    Check out my build thread (Beginning of Money Pit)
    dented rim? brakes?
  4. Apr 3, 2012 at 2:28 AM
    n0ms
    n0ms Well-Known Member
    Angel
    San Diego
    1st gen i4 single cab 4x4
    Celica seats, Icon in rear and front with icon ucas, omd leaf springs, deckplate mod, lce header, Tundra brake swap.
    Take that wheel off and poke your nose around.
  5. Apr 3, 2012 at 2:34 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Odds are, the rim is tweaked, the tire has a broken belt, and your suspension sustained some damage. Take it in and have it inspected, tires balanced and aligned to find out. Otherwise, you will only find obvious damage.
  6. Apr 3, 2012 at 6:10 AM
    Nitronick
    Nick
    Oregon City, OR
    nope not tire. rim is fine, no cracks or dents no weights missing. brake is fine, rotated it freely. not my allienment, its rotating up and down not side to side. It just sounds like a big part of my ifs is loose and its moving back when i give it gas, and forward when i brake..
  7. Apr 3, 2012 at 6:25 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Could have loosened the LCA bolt. Have you had it re-aligned? Something might have bent from the impact. Proper alignment can't be checked visually. Tell the alignment shop what happened so they actually look to see if anything is bent and don't just try to realign something that might be bent.
    Can you shake the wheel without moving the truck, indicating a bearing issue?
  8. Apr 3, 2012 at 6:34 AM
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    I doubt you'll figure this out on your own, so my suggestion would be to take it in, balance the tires get it aligned and go from there. Alignment shop has probably seen this happen so get as much info as you can, that way we can all know what's going on.
  9. Apr 3, 2012 at 6:34 AM
    medic2230
    Murph
    Bama! Roll Tide
    You may have bent the strut. I did that on a mustang once. Chick wasn't even that hot I was looking at either. lol
  10. Apr 3, 2012 at 8:07 AM
    BeerHat
    BeerHat Got Beer?
    TX
    2001 PreRunner 4x4
    PreRunner 4x4, Homebrew Front Bumper, Homebrew Sliders, Homebrew Skids, Homebrew Bedbar, Homebrew Beer
    I would second what Skytower said. Also, just because it was moved to rear does not mean that the tire/rim is fine, a broken belt will still vibrate the truck.
  11. Apr 3, 2012 at 10:31 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Damage to tires, rims, and suspension are not usually able to be seen. Just because the weights are there only means they weren't knocked off. It does not mean the rim is good.
    Balancing the bare rim will tell you if the rim has been bent. Bent=discard(especially with aluminum rims). With a known good rim, balance the suspect tire. Balance=ok. Personally, I wouldn't trust a tire that has taken a very hard hit. That's my head talking, not my wallet. My head knows best; the wallet is a cheap bastard.
