Very bad rub .
Discussion in 'Wheels & Tires' started by Toystacoma06, Jan 12, 2020.
  1. Jan 12, 2020 at 5:53 AM
    Toystacoma06
    Toystacoma06 [OP] New Member
    Frank
    2006 Toyota Tacoma
    2006 Toyota Tacoma
    Recently purchased a 2006 Tacoma and put a 3 inch leveling kit can audit still have the stock tires on the vehicle when I backed up and cut the wheel all the way it is making a horrible grinding sound or rubbing sound that should say. Any ideas to what it might be?
  2. Jan 12, 2020 at 5:57 AM
    TacoRated
    TacoRated Do the chickens have large talons?
    Colorado
    2016 DCSB TRD OR
    High speed, special purpose duct-tape noise cancellation LCAs. Redline Tuning hood struts Hefty Fabworks Rock Sliders Trifold Bed Cover TRD Pro Grille
    Welcome to TW. We need a little bit more information. I doubt they’re the stock tires. Do you mean stock tire size? You might want to double check and post the size. Also, did you install aftermarket UCAs along with the lift?
  3. Jan 12, 2020 at 5:59 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    As you're backing up, once you hear the sound, immediately stop. Hop out and take a peek in the wheel well. That'll give you an answer.
    JCWages and pa blaster like this.
  4. Jan 12, 2020 at 7:01 AM
    Toystacoma06
    Frank
    2006 Toyota Tacoma
    2006 Toyota Tacoma
    Not sure what UCAs are
  5. Jan 12, 2020 at 8:37 AM
    JCWages
    JCWages Well-Known Member
    Grass Valley, CA
    2018 GMC Canyon SLE 4x4
    King 2.5 coilovers, 33s, steel bumpers and stuff.
    Upper Control Arms.
